low speed, wired or wireless
craig86
My connection speed was 30Mbs, but the last week or so it has slowed down to 14Mbs, this is the same wireless or wired. There is no noise on the line, please can you check your side for the problem thanks
1 REPLY
Fixes: 465
Re: low speed, wired or wireless
My tests are showing your router in sync at about 20mbps and has identified a possible fault.
Sync Status In Sync
Downstream Speed 20.0 Mbps
Upstream Speed 2.0 Mbps
Mind spending two minutes to raise this to us at http://faults.plus.net letting us know once you've done and we'll push it through to our suppliers?
