low speed on fibre
sultan
low speed on fibre
Being so annoyed with low speed, I've just been on the which? site for reviews on broadband providers, they rated plusnet's speed very low with poor performance n the new router.  They also listed some 'myths' that annymoius testers got on querying sped-interference from other electric devices, too far from centres, bad weather and more, which I've been told by customer services.  I'd advise anyone disappointed by speed to go to the Which? site
1 REPLY
Fixes: 62
Re: low speed on fibre
From memory - as I have only seen second hand reports - that was checking wireless speeds
FTTC speed - that is synch speed - is entirely dependent on your distance from the cab although it can be further degraded by line quality (inside and outside your property)
A far more representative set of speed results are found here http://www.thinkbroadband.com/news/7546-uk-broadband-speed-test-results-for-october-2016.html
