low speed on fibre
bigbearuk101
low speed on fibre
can anyone explain why although I have 20mbps speed on my fibre connection I have trouble watching movies, the films are out of sync and keep stalling, any help would be appreciated
Fixes: 162
Re: low speed on fibre
Do you watch the films over wired or wireless connection? If it's wifi, can you try plugging a cable in and seeing if this helps to alleviate the issue.
 Chris Parr
 Plusnet Staff
bigbearuk101
Hi Chris
thanks for your reply
I am on wired, I have a spare computer and getting the same thing, there is a possibility that there is a problem with the motherboards as they are getting a bit long in the tooth so I have a new base unit coming tomorrow, I will set that up and try again if it works then I will let you know, it may help other customers
cheers
walter
