line stats
williamsben16
line stats
can you do a gea test so can see my line stats please having loads problems with latency and interleave
Fixes: 167
Re: line stats
Here you go:
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 32.5 Mbps
Upstream Speed 6.9 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 969.4
Upstream Rate Assessment Good
Downstream Rate Assessment Reasonable
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence ; 00:00 to 23:45
Interference Location Customer Premise
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
Profile Name 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2017-09-06T13:15:00
Those syncs are what I'd expect based on the line estimates:
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 40 30 7.5 5.5 27.4 Available -- -- Yes --
 Chris Parr
 Plusnet Staff
williamsben16
Re: line stats
interference why is it saying its fine im a gamer cant game because of latency up and down really need fixing or im leaving
Fixes: 167
Re: line stats
What pings are you seeing? What game is it and are you connected via ethernet cable or wireless?
 Chris Parr
 Plusnet Staff
williamsben16
Re: line stats
i was using ethernet but swaped to wifi so i could plug direct in socket and wifi is not the problem because some days its been fine dsl stats shows errors low db and interleave 4 on a good day 25ms ping 30ms on bad day and battlefield 1 say network varation which means bad conection
