line stats
- Re: line stats
line stats
19-09-2017 11:14 AM - edited 19-09-2017 11:56 AM
can you do a gea test so can see my line stats please having loads problems with latency and interleave
Re: line stats
19-09-2017 1:12 PM
Here you go:
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 32.5 Mbps | ||||
Upstream Speed | 6.9 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 969.4 | ||||
Upstream Rate Assessment | Good | ||||
Downstream Rate Assessment | Reasonable | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | No Impact Observed | ||||
Interference Duration Longest Occurrence | ; 00:00 to 23:45 | ||||
Interference Location | Customer Premise | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Current 15Min Bin Retrains | 0 | ||||
Last 15Min Bin Retrains | 0 | ||||
Profile Name | 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2017-09-06T13:15:00 |
Those syncs are what I'd expect based on the line estimates:
Featured Products |
Downstream Line Rate(Mbps) |
Upstream Line Rate(Mbps) |
Downstream Handback Threshold(Mbps) |
WBC FTTC Availability Date |
WBC SOGEA Availability Date |
WBC FTTC 18x2 Provide Availability |
WBC FTTC 18x2 Sim Availability |
Left in Jumper |
High | Low | High | Low | |||||||
VDSL Range A (Clean) | 40 | 30 | 7.5 | 5.5 | 27.4 | Available | -- | -- | Yes | -- |
Re: line stats
19-09-2017 1:20 PM - edited 19-09-2017 1:35 PM
interference why is it saying its fine im a gamer cant game because of latency up and down really need fixing or im leaving
Re: line stats
19-09-2017 1:36 PM
What pings are you seeing? What game is it and are you connected via ethernet cable or wireless?
Re: line stats
19-09-2017 1:40 PM - edited 19-09-2017 1:43 PM
i was using ethernet but swaped to wifi so i could plug direct in socket and wifi is not the problem because some days its been fine dsl stats shows errors low db and interleave 4 on a good day 25ms ping 30ms on bad day and battlefield 1 say network varation which means bad conection
