line speed
FIXED- Subscribe to RSS Feed
- line speed
29-03-2018 4:28 PM
hi in connected at 77124 but line speed is only 70mb can someone update this for me ?
Fixed! Go to the fix.
Re: line speed
29-03-2018 4:30 PM
and also is there a update for my hubone ?
Software version 4.7.5.1.83.8.237.2.2 Last updated 08/09/17
Re: line speed
29-03-2018 8:03 PM
01-04-2018 2:47 PM
Hi there.
I've updated your speed profile now. If you do a single disconnect/reconnect in your routers interface you should have a slightly improved throughput.
In addition, our tests are showing a potential line fault which might be why your speeds dropped previously.
I've raised this with our suppliers and we'll update you when we know more.
Re: line speed
03-04-2018 4:10 PM
Re: line speed
03-04-2018 4:20 PM
Hi @staceyd86
The fault that @Gandalf raised to our suppliers will be updated on your account - you can view this by clicking here.
Hope this helps!
Re: line speed
04-04-2018 5:03 PM
faults been fixed now and syncing at....
4. Board version: | Plusnet Hub One |
5. DSL uptime: | 0 days, 00:05:17 |
6. Data rate: | 20000 / 78330 |
7. Maximum data rate: | 27404 / 78472 |
8. Noise margin: | 9.9 / 6.0 |
9. Line attenuation: | 13.6 / 11.2 |
10. Signal attenuation: |
13.3 / 11.2 |
can you please update my profile speed again as it has went back to 70mb after its went down to be fixed
Re: line speed
04-04-2018 6:06 PM
Re: line speed
13-05-2018 6:31 PM
can you do my line speed again please,
Data rate: |
20000 / 78571 |
line speeds set to 73mb
Re: line speed
14-05-2018 6:58 AM
its gone to 76mb now but should it not be set to 79mb ?
Re: line speed
15-05-2018 6:05 PM
can anyone sort this please ?
Re: line speed
15-05-2018 6:11 PM
Re: line speed
16-05-2018 9:28 PM
ive had it above 76mb, can a admin do this for me please ?
Re: line speed
17-05-2018 10:53 AM
Re: line speed
18-05-2018 7:12 AM
its still at 76mb profile
