line speed dropped to 21 Mb
rhohne
Is there a particular reason why my line speed has dropped to ADSL values or is it just another bug in the PN system?
Estimated line speed:There's no speed estimate currently held on your account.Current
line speed:21 Mb
Stats recorded 23 May 2016 20:20:42
DSLAM/MSAN type:        	IFTN:0xb204 / v0xb204
Modem/router firmware:  	AnnexA version - A2pv6F039o1.d26a
DSL mode:               	VDSL2 Profile 17a
Status:                 	Showtime
Uptime:                 	5 days 1 hour 10 min 44 sec
Resyncs:                	0 (since 18 May 2016 19:49:39)
				Downstream	Upstream
Line attenuation (dB):  	26.5		0.0
Signal attenuation (dB):	Not monitored
Connection speed (kbps):	34997		5251
SNR margin (dB):        	3.0		6.3
14 REPLIES 14
SpendLessTime
Fixes: 86
Re: line speed dropped to 21 Mb
Another bug is very likely.
Give Plusnet a call or Chat or hope a member of Staff picks this up.
adamwalker
Fixes: 221
Hi rhohne,
Diagnostic tests are indicating a fault which is likely to be causing this.
I'd head over to http://faults.plus.net for troubleshooting advice, this will also allow you to report the fault with us if you're unable to resolve the issue yourself.
 Adam Walker
Chris
Legend
Fixes: 169
Don't worry about reporting a fault. Just try a disconnect/reconnect now and see what the speeds are like.
rhohne
Current line speed bumped to 37Mb between 12:00 and 12:25
Dropped back to expected 33.8Mb at 18:30 on disconnect/reconnect as requested by Chris
Estimated line speed still missing
rhohne
Is there any further info on "Diagnostic tests are indicating a fault which is likely to be causing this"
Chris
Legend
Fixes: 169
I'm not sure what Adam was referring to, the problem was that the profile on our side was set incorrectly at 21Mb. I fixed this and you saw an increase in speed.
The estimated speed being absent from that page is going to cause zero issues.
portreath75
Chris,Sorry for butting in on someone elses thread but my line has gone to 21Mb as well and should be 38,is it possible you could check to see if my profile at your end has been set incorretly please.
rhohne
Have applied the known fudge to get my estimate back
Chris
Legend
Fixes: 169
Should be fixed now.
wartywarlock3
I'm also experiencing a similar drop from advised 76mb, only getting around 20.
Pnet name wartywarlock3
Chris
Legend
Fixes: 169
Your's doesn't seem to be the same issue, the profile is set correctly. Can you run a BT Speedtest and do the further diagnostics after the first part completes please. http://speedtest.btwholesale.com/
wartywarlock3
Currently out but I'll do this asap, but various speedtests at random times have gone from ~50/25 originally to as low as 15/8 u/d with extreme variations in ping, anywhere from 10ms up to 300+
Is there any difference in the BT boxes (the 'modem' part as it were) as we have the same old one from when fibre was first available. It seemed to be fine at 40mb at my old home tho. It then links into a very high end Asus router so everything should be dandy in that sense.
rhohne
This thread is going off topic. It has nothing to do with speed tests but with the following four fields been removed/incorrect
    Telephone number:
    Phone exchange:
    Current line speed:
wartywarlock3
Basic BT test:
11.74 / 8.57, 34ms ping.
Advanced:
1. Best Effort Test: -provides background information.
Download Speed
11.74 Mbps
0 Mbps 77.43 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 11.74 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-77.43 Mbps .
 Additional Information:
 IP Profile for your line is - 77.43 Mbps
Upload Speed
8.57 Mbps
0 Mbps 20 Mbps
Will run the next test shortly.
