line reset
williamsben16
line reset
having loads of problems with my line cutting out snr margin to low 3.8 / 4.8
9 REPLIES 9
Fixes: 1,600
Re: line reset
We can't reset fibre lines I'm afraid.
There don't seem to be many drops in the physical connection:
Testing your line isn't showing any issues either. Are you using a wireless or wired connection?
Thanks,
Anoush
williamsben16
Re: line reset
wired connection why is my line noise so low and interleave gone up im gamer and pay alot of money for internet
Fixes: 1,600
Re: line reset
That's not something we've any control over. The profile is set by the DLM [Dynamic Line Management] at the exchange.
Apart from the SNR margin fluctuating, what problems are you experiencing?
williamsben16
Re: line reset
so theres nothing you i can do about dlm i do lag alot sometimes
Fixes: 1,600
Re: line reset
Unfortunately not. We don't have any remote tools over fibre DLM like we have for ADSL.
When things lag, do you experience slow speeds on a test?
williamsben16
Re: line reset
no i dont get slow speeds when i test which is weird
Fixes: 1,600
Re: line reset
Can you run a traceroute to the gaming server you're having problems with when the issues occur?
williamsben16
Re: line reset
fixed now phone was the problem unplugged it disconnected plugged it in disconnected so unplugged and line more stable thanks 4 help
Fixes: 1,600
Re: line reset
No problems at all, glad to hear we got to the bottom of that.
