??line fault
- ??line fault
- « Previous
- 1
- 2
- Next »
Re: ??line fault
23-02-2015 9:56 PM
Just another question. With fibre how do you know if you are losing sync or what the uptime of the connection is. Just asking as speedtests have become very choppy, but actual speeds ok. Once even got to 56mbps although I am on the 40mb product. Tbb test appears to be the most reliable. Would an all in one router give me sync etc, ot would another router give me sync and uptime s etc. Sorry to ask alot, not used to all of this. Any advice on an all in one product?
Message 16 of 24
(237 Views)
Re: ??line fault
25-02-2015 1:08 PM
Things seem ok. Profile staying at 40mb and downloads very quick. Just wondered what my line profiles were as im interested in this kind of thing. Is there any way of seeing the dsl up times with the modem/router configuration. Bit new to all this and interested to find out how things work. Question. .. why do bt not want us to see the line stats?Surely it would be useful from a fault perspective
Message 17 of 24
(237 Views)
Re: ??line fault
25-02-2015 2:12 PM
Message 18 of 24
(237 Views)
Re: ??line fault
25-02-2015 3:51 PM
The Plusnet Router will not show Line Stats for FTTC!
BT Wholesale speed tester (http://speedtest.btwholesale.com/) will give the line profile if you complete 'further diagnostics', this will be about 97% of your sync speed (or sync is about 103% of the indicated IP profile. Other stats are only available on unlocked BT modems or all-in-one devices.
Call me 'w23'
Message 19 of 24
(237 Views)
Re: ??line fault
25-02-2015 7:25 PM
Yeah thanks. Got no info on line stats. Can never get the additional info from the bt tester. Thanks anyway.
Message 20 of 24
(237 Views)
Re: ??line fault
01-03-2015 9:15 PM
Been a week now since the install. All seems fine. Just concerned by the speedtest results, all appear quite random to be honest... The graphs look very sawtoothy, and there is a large varience between different testers. The Plusnet profile has not moved from 40Mb though, and downloads come through at approx 2.0 - 3.5Mbps, which I am presuming is OK.
Managed to get a full BT speedtest to run, which said download was 22Mbps and was RED, upload was 15Mbps. IP profile was 77.68. TBB speedtests though were giving me 33-38Mbps
Im just a little confused.
Could someone look at the line profiles etc, and let me know if there is an issue at all. Unsure if I have had any resyncs since the install, as I cant check this. Router WAN uptime says
Board ID: F@ST2704N
HardWare Version: F@ST2704N V1.0
Serial Number: N7143561M005558
Mac Address: 44:e9:dd:0e:a2:88
Build Timestamp: 141118_1136
Software Version: 7.273.1_F2704N_Plusnet
Bootloader (CFE) Version: 7.273.1
DSL PHY and Driver Version: A2pG039f2.d25b
Wireless Driver Version: 5.100.138.2008.cpe4.12L06B.4
Uptime: 6D 4H 19M 19S
Not sure if there is anymore info available from the router interface
Board ID: F@ST2704N
Message 21 of 24
(237 Views)
Re: ??line fault
03-03-2015 5:33 PM
Odd things happening last night....
The internet seems very choppy at best. I was downloading a program in HD from Sky on demand (ITV Player), and whilst it was not buffering, it took a while before I could start watching it, and downloaded the 2.3Gb in just over 30mins. This was at 9.30 last night. I downloaded another episode at 10.30, same program, and from ITV player via Sky on demand, and the program was available in less that 20secs to view, and downloaded the whole 2.3gb in less than 20mins. I would really appreciate some feedback from the COT, regards the quality of my line, what the current line stats are, and am I just seeing congestion on my Cab. I am connected to the Blackburn exchange in Lancashire, on Cab55. Installer mentioned there were 80odd people already connected in this Cab.
I am not on the full Fibre package, just the 40Mb package.
Thanks in advance
Thanks in advance
Message 22 of 24
(237 Views)
Re: ??line fault
04-03-2015 2:43 PM
Message 23 of 24
(237 Views)
Re: ??line fault
04-03-2015 7:53 PM
Hi tony
sorry, thoses speeds were download throughput, not speedtester speeds. I was really wondering if there were any capacity issue. According to the plusnet router I have not lost ppp since install. Could you confirm and maybe post mu radius logs. Can you see if there have been any losses of sync at all, and maybe post up my stats and line profile. Can't get used to not having any info to hand
on another note, are plusnet going to supply a vdsl router soonish and if so, would existing customers be able to get one?
thanks in advance
thanks in advance
Message 24 of 24
(237 Views)
- « Previous
- 1
- 2
- Next »
