line / connection check please - slow upload
- line / connection check please - slow upload
28-04-2015 11:26 PM
Hi, recently my upload speeds have been less than 1mb.
When i first joined i was getting 53Mbps down and 13Mbps up. Lately the down has been about 35Mbps but the upload rarely gets over 1Mbps.
Which is a bit annoying to say the least.
Could someone just have a look to see what they can do please.
Message 1 of 4
(680 Views)
3 REPLIES 3
Re: line / connection check please - slow upload
29-04-2015 11:04 AM
I look at the BTW Performance Test results and shake my head.
Not so long ago (weeks, rather than months) results showed Red if there was something wrong, but more recently they show green by dropping the maximum expected speed to suit. That's on the Download.
On the Upload, I used to get red when speed fell below half possible, or thereabouts, I suspect that yours will show green even if you need to zoom to 500% to see it.
There is a problem with dropping speeds yet BTO's solution seems to be pretending otherwise. What does that do for Customer relations.
Message 2 of 4
(382 Views)
29-04-2015 1:24 PM
I've run a line test and cross talk is detected. I'm putting it down to this because the 13Mbit that you used to get is better than the current estimates (highest on a clean line 11.8) going down to 5.2Mbit impacted.
Still you are showing as having 4.3MBit, so we may need to investigate further - please raise via faults.plus.net.
Message 3 of 4
(382 Views)
29-04-2015 9:20 PM
hi, thanks for the help. will report as a fault
cheers
cheers
Message 4 of 4
(382 Views)
