line check
Haffoc
line check
Could someone check if I am fastpath or interleave please?
I'm syncing at 79/18 but am being throttled at a max of 66 throughput which are speeds I used to get when I was syncing at 69-70.
Fixes: 65
Re: line check
Hi there, you appear to be on fastpath and the line profile does seem to be in line with your sync speeds.
Were you connecting over WiFi when testing? Would be a good idea to try  that over ethernet if so.
 Adam Walker
Haffoc
Re: line check
Thanks for the reply.
I'm wired directly to the router/modem. I guess it's probably contention ratio related at my exchange.
Fixes: 382
Re: line check
Hi there.
Our tests aren't showing any congestion at your exchange.
From what I can see your profile updated slightly from 69mbps to 73mbps last Wednesday night.
If you do a single disconnect/reconnect of the PPP session in your router settings you might see a small speed boost.
Haffoc
Re: line check
I understand that openreach have come up with a solution to perform a remote DLM reset.
Is this something that you could? Perhaps dlm has limited my line despite syncing between 75-79mb?
Fixes: 382
Re: line check
From what I can see, your line isn't banded by DLM:
Profile Name 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off
As your line is in sync at 71mbps there's not much we can do to improve this further I'm afraid.
