line check
- Re: line check
line check
28-03-2018 8:21 PM
Could someone check if I am fastpath or interleave please?
I'm syncing at 79/18 but am being throttled at a max of 66 throughput which are speeds I used to get when I was syncing at 69-70.
Re: line check
29-03-2018 4:59 PM
Hi there, you appear to be on fastpath and the line profile does seem to be in line with your sync speeds.
Were you connecting over WiFi when testing? Would be a good idea to try that over ethernet if so.
Re: line check
29-03-2018 5:52 PM
Thanks for the reply.
I'm wired directly to the router/modem. I guess it's probably contention ratio related at my exchange.
Re: line check
31-03-2018 5:28 PM
Hi there.
Our tests aren't showing any congestion at your exchange.
From what I can see your profile updated slightly from 69mbps to 73mbps last Wednesday night.
If you do a single disconnect/reconnect of the PPP session in your router settings you might see a small speed boost.
Re: line check
09-04-2018 3:01 PM
Is this something that you could? Perhaps dlm has limited my line despite syncing between 75-79mb?
Re: line check
09-04-2018 3:44 PM
From what I can see, your line isn't banded by DLM:
Profile Name | 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off |
As your line is in sync at 71mbps there's not much we can do to improve this further I'm afraid.
