just had fibre upgrade when do speeds increase?
g4jnw
Engineer has just been about an hour ago and I'm wondering when my speeds will increase, done a line test and download is the same as it was pre fibre, upload speed has gone up a bit.
He installed a new faceplate.
Fixes: 193
Re: just had fibre upgrade when do speeds increase?
It looks like the order is still showing committed so it may not have triggered all of the updates on the account just yet.
I'll make a few manual changes to try and sort this while we're waiting for the completion notification to come through Wink
You may need to disconnect and reconnect for the new speeds to kick in.
 Harry Beesley
g4jnw
Thanks Harry - quite excited - Rural Cumbria in the fast lane (almost)  Grin
g4jnw
Have disconnected and reconnected and the speed has gone up so am happy, i presume it will take a few days to settle but thanks Harry for whatever you did.
Fixes: 193
No problem, glad to hear the speeds have improved.
 Harry Beesley
