just had fibre upgrade when do speeds increase?
- Re: just had fibre upgrade when do speeds increase...
22-01-2016 11:37 AM
Engineer has just been about an hour ago and I'm wondering when my speeds will increase, done a line test and download is the same as it was pre fibre, upload speed has gone up a bit.
He installed a new faceplate.
Message 1 of 5
(758 Views)
4 REPLIES 4
Re: just had fibre upgrade when do speeds increase?
22-01-2016 11:39 AM
It looks like the order is still showing committed so it may not have triggered all of the updates on the account just yet.
I'll make a few manual changes to try and sort this while we're waiting for the completion notification to come through
You may need to disconnect and reconnect for the new speeds to kick in.
Message 2 of 5
(424 Views)
22-01-2016 11:41 AM
Thanks Harry - quite excited - Rural Cumbria in the fast lane (almost)
Message 3 of 5
(424 Views)
22-01-2016 12:01 PM
Have disconnected and reconnected and the speed has gone up so am happy, i presume it will take a few days to settle but thanks Harry for whatever you did.
Message 4 of 5
(424 Views)
22-01-2016 2:05 PM
Message 5 of 5
(424 Views)
