is this the right line speed ?
matty2k13
Current line speed:  73.4 Mb
6. Data rate: 20000 / 79995
7. Maximum data rate: 27254 / 80460
8. Noise margin: 9.5 / 6.6
9. Line attenuation: 0.0 / 10.5
10. Signal attenuation: 0.0 / 10.5
Fixes: 62
Re: is this the right line speed ?
Nope
Should be 77.4
matty2k13
thanks jim, wont get changed till monday now tho ?
matty2k13
should have a line speed of 77.4 on plusnet side but its only 73.4
Rich: at 11:00:54
Ok what's telling you it should be 77.4Mbps?
why is this person working for plusnet if they dont know what my line speed should be ?
matty2k13
can a admin sort my linespeed out on monday please. Crazy
Fixes: 62
why don't you phone in after doing a BT speed test - further diagnostics to check the IP profile
matty2k13
Line speed on bt speed test says ip profile is 77.4mb. Will ring them in the morning
matty2k13
Download speedachieved during the test was - 66.59 Mbps
For your connection, the acceptable range of speedsis 60 Mbps-77.43 Mbps .
Additional Information:
IP Profile for your line is - 77.43 Mbps
Upload speed achieved during the test was - 13.88Mbps
matty2k13
Well didnt get time to ring over the weekend. So could a admin please update my current line speed. Thanks
Plusnet Staff
Plusnet Staff
Fixes: 4
Hi Matty,
I've sorted this for you this morning. Sorry for the delay.
matty2k13
thanks, back up to 73.5mb Smiley
matty2k13
sorry to post again but had a few power serges the other day and my line speed went back down, any chance you cold change it again please admin  Cry
Fixes: 5
I'm having a few problems testing your line. I've therefore changed the profile from our side which should reflect in a moment.
 Tony T
