is this correct
andytay
is this correct
Hi all,
I have just used ookla speed test and its showing my provider as BT? Isnt my Provider Plusnet or has ookla got it wrong?
4 REPLIES 4
Awwk
Re: is this correct
I had the same thing, but it changed to Plusnet after a couple of days
andytay
Re: is this correct
Its not the first time i noticed it, the first time was a month ago when i moved to a new house.
Fixes: 419
Re: is this correct
You're still with Plusnet. It's just that the IP address you're currently allocated was originally registered to BT.
Fixes: 1,600
Re: is this correct
Pretty much what @Baldrick1 said.
There's nothing to worry about. Smiley
