internet keeps disconnecting
goatty2
so far today been kicked off internet 3 times since 9am and noise on phone line while internet down which clears when internet back on
had a problem yesterday afternoon when it down for 10 mins with noise on landline which cleared when internet back up
Fixes: 4
Re: internet keeps disconnecting
Do what I did, and report a fault on your landline.
If you go to the BT page, there is a section where they test your line and offer you an option to send an engineer out.
All you can do is disconnect all extensions first (to rule them out being the problem), and just have one thing plugged into the master socket.
goatty2
done that and said no fault on line as the internet was working and only get noisy landline when internet down
don't think had any drop outs since this morn
Fixes: 181
Sorry to hear you've had drops in connection.
From what I can see it was dropping but now appears to be stable as shown below
Our tests aren't showing any cause for this either.
If the drops continue I'd recommend raising a fault here
 Matthew Wheeler
goatty2
thanks  Matthew
had no drop outs since
speed down a little 1-2mbs
otherwise seams ok
Fixes: 181
Glad to hear it
Let us know if you have any issues in future,
 Matthew Wheeler
