intermittant browsing issues, anyone else
- intermittant browsing issues, anyone else
10-10-2014 6:57 PM
For the last two night i have had intermittent browsing issues where one second a page can load then the next the server cannot be found.
Re-booting the bt modem brings it back for a while then it's off again.
Anyone else having similar issues.
Message 1 of 6
(3,751 Views)
5 REPLIES 5
Re: intermittant browsing issues, anyone else
10-10-2014 7:15 PM
well ive just posted about something thats like that. can you see if the light has changed on your router,mine was flashing orange(home hub 5)
Message 2 of 6
(1,609 Views)
10-10-2014 8:04 PM
[tt]
192.168.0.15 0.54/0.54/0.55/0.00/0
208.67.222.123 17.78/17.96/18.14/0.13/0
208.67.220.123 17.73/18.25/19.30/0.57/0
208.67.222.222 17.49/17.85/18.38/0.35/0
208.67.220.222 17.50/17.89/18.11/0.21/0
212.159.6.9 17.46/19.10/24.51/2.72/0
212.159.6.10 17.93/18.36/18.80/0.34/0
212.159.13.49 17.34/17.54/17.72/0.14/0
212.159.13.50 17.51/18.16/18.61/0.36/0
8.8.8.8 23.34/23.69/23.88/0.19/0
8.8.4.4 23.66/23.89/24.53/0.32/0
Nameserver Response Time (ms)
min/avg/max/stdev/retries
192.168.0.15 0.54/0.57/0.68/0.05/0
208.67.222.123 17.71/18.00/18.22/0.22/0
208.67.220.123 17.47/18.08/19.16/0.59/0
208.67.222.222 17.89/18.08/18.19/0.12/0
208.67.220.222 17.59/18.09/18.80/0.40/0
212.159.6.9 17.11/17.66/18.34/0.41/0
212.159.6.10 17.40/17.88/18.49/0.44/0
212.159.13.49 17.23/19.28/25.72/3.24/0
212.159.13.50 17.30/17.55/17.74/0.16/0
8.8.8.8 23.65/23.80/23.97/0.12/0
8.8.4.4 23.58/23.71/23.84/0.09/0
[/tt]
I can see some elevation of plusnet dns-servers tonight.. but browsing should be ok though in the main.
[/tt]
Message 3 of 6
(1,609 Views)
10-10-2014 10:59 PM
BT modem light is going on and off faster than i can blink
Message 4 of 6
(1,609 Views)
11-10-2014 7:45 AM
not noticed anything and swmbo hasn't shouted at me either so must be ok
using opendns here.
using opendns here.
Message 5 of 6
(1,609 Views)
11-10-2014 10:17 AM
I have had slow/failed loading from specific sites, in particular it can take 3+ attempts to load ancestry.co.uk (blank page, partial page or ?javascript not completing? ). Other sites seem to load as expected.
Interestingly, I don't recall this happening before the change to fibre at the end of September
DNS is via a local machine forwarding to opendns with Plusnet as tertiary. Overriding that setting and using google ( 8.8.8.8 ) gives the same effects.
Phil
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Message 6 of 6
(1,609 Views)
