install of fibre
lenny
install of fibre
i have just transferred from Plusnet adsl to Plusnet fibre 'at the moment everything seams ok ,but the chap who came to do the install did not seam to have a clue , i had installed my own data extension and the last time an engineer was here he installed a mk3 face plate , this was not an Openreach engineer but a contractor, he gave me an eci modem and when i asked for a  Huawei modem his answer was they dont make them any more and this is all we can get from our stores Smiley
he could not fathom out how to connect the eci modem to the data socket , i had to show him, there was no test of the line at my house to attain what speed i should receive , he never plugged anything in my socket to check the line, once the lights on the router where lit i had to check on my pc that all was working and do a BT speed test,
but at least things are working ,just glad i did not have to pay for the install with my attain rate higher would i be better on the 80/20 package
i was told i would get
and these are my stats
adsl info --stats
adsl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason:    0
Last initialization procedure status:   0
Max:    Upstream rate = 9353 Kbps, Downstream rate = 57783 Kbps
Bearer: 0, Upstream rate = 1999 Kbps, Downstream rate = 39973 Kbps
Link Power State:       L0
Mode:                   VDSL2 Annex B
VDSL2 Profile:          Profile 17a
TPS-TC:                 PTM Mode(0x0)
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
               Down            Up
SNR (dB):        15.9            28.9
Attn(dB):        25.3            0.0
Pwr(dBm):        12.8            4.8
11 REPLIES 11
lenny
Re: install of fibre
spoke to soon , can i get my plusnet ip profile reset 40mb please,
sorted got straight threw on the phone and they altered for me
thanks
philto
you could be conected to an eci box in the street I think they have to match
lenny
I am connected to a Huawei cab
Terranova667
Fixes: 5
If your on a Huawei cab then you may want to get yourself a modem that can do G.INP on both up and down once it's enabled on your line the Openreach ECI modem can not do upload G.INP.
this would have to be at your own expense however so it's your call if you wish to do this.
lenny
I bought a Billion BiPac 8800nl and have had that connected since going over to fibre , a great all in one and we'll worth  the money  Smiley
Oldjim
Resting Legend
Fixes: 63
+1
Does everything I want including supporting stats monitoring software
chenks76
All Star
Fixes: 12
how can you tell which your cab is?
is it identifiable from the outside of the cab?
Oldjim
Resting Legend
Fixes: 63
usually the ADSL Cab has the number painted on it and the fibre cab is next to it
chenks76
All Star
Fixes: 12
no, whether it's ECI of Huawei Roll_eyes
Oldjim
Resting Legend
Fixes: 63
chenks76
All Star
Fixes: 12
it's a Huawei 288
