incoming vpn
- Re: incoming vpn
incoming vpn
15-12-2015 4:51 AM
So here's my problem - one reason for getting high speed UPLOAD ability - is to access my media when I am not at home. As this has to be secure the obvious way is to use a VPN - so that from an external location you would VPN into the house.
The problem is that the very lacklustre Plusnet Plus One router has no ability to do this at all. I have routers such as a Draytek and TP-LInk both of which will allow creation of VPNs.. but they won't talk to the fibre.
So - I'm trying to get my head around this.. how would you set up port forwarding on the - such that a second, internal router could provide the VPN capability? The kind of VPN I'm talking about is the kind you can set up by default on most Android and other tablets...
So for example If I were to port forward TCP Port 1723 for link setup, and IPSec/ESP Port 500 to an internal router that had VPN ability- would that work? I read something about protocols and I think I saw something like GRE whereas the Plus one offers TCP or UDP only - I'm not sure even if that is relevant...
Re: incoming vpn
15-12-2015 7:59 AM
Using two routers is possible but you'll be going through two port address translation processes and may run into issues with double port forwards etc.
Re: incoming vpn
15-12-2015 9:16 AM
Quote from: pwatson By far the simplest way of achieving this would be to buy a BT Openreach modem from eBay and use one of your existing routers. Alternatively you could use a Raspberry Pi as a VPN server or you may already have another device that can do this (NAS perhaps, or the machine holding the media you need to access?)
Hi
enlighten me please... BT Openreach - why? And (this is likely a REALLY stupid question) as the PlusONE has a DMZ option - is there a reason I can't just point the DMZ to my draytek - and use the Draytek to do everything like address allocation, VPN etc... on the surface that SEEMs like a practical solution or am I bypassing a load of security doing that?
Pete
Re: incoming vpn
15-12-2015 9:26 AM
Re: incoming vpn
15-12-2015 9:33 AM
I'm hoping to try a more expensive Draytek 2830 tomorrow.. the think is the VDSL connection on that modem is an RJ45 whereas what we have coming in from Plusnet is the smaller version you'd normally use for ADSL....
Quote from: Andrue Are you sure you can't do it the other way around, access a VPN hosted at your office? I wouldn't be happy having a VPN endpoint running on domestic equipment. That's one more door you're presenting to the internet and it has a bright ring of flashing lights around it and a message saying 'This is where I keep the crown jewels'. I think it'd be far better to leave VPN hosting to business grade equipment.
Re: incoming vpn
15-12-2015 9:46 AM
Re: incoming vpn
15-12-2015 9:55 AM
Really - Plusnet should be able to answer all of this - after all that's what they do for a living - but it seems not.
Quote from: Mook This may be of interest to you then:
https://www.draytek.co.uk/archive/vpn_setup.html
Re: incoming vpn
15-12-2015 10:40 AM
Quote from: scargill So - I'm trying to get my head around this.. how would you set up port forwarding on the - such that a second, internal router could provide the VPN capability? The kind of VPN I'm talking about is the kind you can set up by default on most Android and other tablets...
Never tried it on tablets, but you can configure a Windows PC to accept incoming PPTP VPN connections. In this case, as you say, you'd need to forward port 1723.
If you still can't connect into the VPN server on your LAN then you may also need to enable VPN passthrough on the Plusnet router. Whether it allows this or has an explicit option for it, I'm not sure though, as I've never really used any of the HomeHubs or their variants. Until I got Fibre I always stuck with DD-WRT routers, and now use an Asus RT-N66U with OpenReach ECI modem.
Re: incoming vpn
15-12-2015 12:02 PM
Quote from: dannyboy75
Problem solved - another member pointed out that for non-Plusnet modems you need a password - same as your account password - that in the TP-Link is working a TREAT.
Re: incoming vpn
15-12-2015 12:12 PM
