imgur.com been slow all week now unreachable
- imgur.com been slow all week now unreachable
Re: imgur.com been slow all week now unreachable
30-01-2016 10:49 PM
If anyone is having a problem with imgur; https everywhere plugin for firefox or just using https:/www.imgur.com has fixed it for me,
I think imgur is filtered by the IWF but as they hve millions of users and are trying to fileter specific urls the plusnet or iwf cache is failing, would be good to know if plusnet or iwf are causing the problem.
GET / HTTP/1.1
Host: www.imgur.com
User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:35.0) Gecko/20100101 Firefox/35.0
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language: en-US,en;q=0.5
Accept-Encoding: gzip, deflate
Connection: keep-alive
HTTP/1.0 302 Moved Temporarily
Retry-After: 0
Content-Length: 0
Accept-Ranges: bytes
Date: Sat, 30 Jan 2016 14:33:51 GMT
X-Served-By: cache-lhr6320-LHR
X-Cache: HIT
X-Cache-Hits: 0
Server: cat factory 1.0
Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
X-Frame-Options: DENY
X-Cache: MISS from pcl-iwfcache01.plus.net
X-Cache-Lookup: MISS from pcl-iwfcache01.plus.net:80
Via: 1.0 pcl-iwfcache01.plus.net:80 (squid)
Connection: close
Source: pcl-iwfcache02.plus.net (212.159.3.234)
83 55.866258000 pcl-iwfcache02.plus.net 192.168.1.46 ICMP 90 Time-to-live exceeded (Time to live exceeded in transit)
GET / HTTP/1.1
Host: www.imgur.com
Cookie: SESSIONDATA=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
HTTP/1.1 302 Moved Temporarily
Retry-After: 0
Content-Length: 0
Date: Sat, 30 Jan 2016 16:25:55 GMT
Connection: close
X-Served-By: cache-lhr6335-LHR
X-Cache: HIT
X-Cache-Hits: 0
21 7.146760 192.168.1.46 185.31.19.193 TCP 54 43939 → 443 [ACK] Seq=1 Ack=1 Win=66560 Len=0
GET / HTTP/1.1
Host: imgur.com
HTTP/1.1 200 OK
Content-Type: text/html; charset=utf-8
Cache-Control: max-age=60, stale-while-revalidate=600, stale-if-error=86400, public
Fastly-Debug-Digest: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Content-Length: 151913
Date: Sat, 30 Jan 2016 16:25:56 GMT
X-Served-By: cache-iad2127-IAD, cache-lhr6324-LHR
X-Cache: HIT, HIT
X-Cache-Hits: 2, 3
Vary: Accept-Encoding
30-01-2016 11:23 PM
30-01-2016 11:37 PM
Quote from: Ravencroft Can anyone suggest a free vpn I can use till this fixes? I pay a subscription to nexusmods.com and of course I can't even use it at the moment.
I downloaded CyberGhost since it was listed as free and doesn't throttle the connection, free version worked fine for me to be able to download 19gb worth of client data for TSW. Free version has a 3 hour limit for the connection then you need to reconnect (and there's normally a queue that starts around 3000ish to get a connection but the queue number went down to 0 in < 2 mins and then I was connected. http://www.cyberghostvpn.com/en_gb?utm_expid=85864364-20.eNBY82fVRQSTe-9mpnQtJw.0
31-01-2016 12:38 AM
Can't be anything but a plusnet issue if https works as fast as it can and http doesnt...
Meh, the time it takes between issues cropping up and getting fixed with PN is pretty poor 😐
31-01-2016 9:45 AM
31-01-2016 1:14 PM
31-01-2016 2:05 PM
C:\Users\John>nslookup i.imgur.com
Server: cdns01.plus.net
Address: 212.159.6.9
Non-authoritative answer:
Address: 185.31.18.193
Aliases: i.imgur.com
C:\Users\John>nslookup i.imgur.com 8.8.8.8
Server: google-public-dns-a.google.com
Address: 8.8.8.8
Address: 185.31.19.193
31-01-2016 2:12 PM
31-01-2016 3:22 PM
31-01-2016 3:43 PM
31-01-2016 4:05 PM
Quote from: ejs This was not a DNS issue. The IP address of imgur.com has not changed. There was no problem resolving the IP address. OK now I've noticed it's got two IP addresses, 185.31.18.193 and 185.31.19.193. You will get one or other of those IP addresses regardless of if you use Plusnet's DNS servers or Google DNS.
You get 185.31.18.193 or 185.31.19.193 at random regardless of what DNS servers you use. For imgur.com specifically, another workaround might be to add an entry to your hosts file with whichever of those IP addresses doesn't go through the IWF filter, which was apparently the one with .19.
31-01-2016 6:18 PM
traceroute to 185.31.19.193 (185.31.19.193), 64 hops max, 52 byte packets
1 192.168.29.1 (192.168.29.1) 2.470 ms 1.143 ms 1.966 ms
2 195.166.130.220 (195.166.130.220) 8.894 ms 8.358 ms 8.925 ms
3 link1-central10.pcl-ag07.plus.net (84.93.249.193) 10.209 ms 11.845 ms
link2-central10.pcl-gw02.plus.net (84.93.249.194) 8.378 ms
4 ae2.ptw-cr01.plus.net (195.166.129.4) 42.773 ms 9.826 ms
ae1.pcl-cr02.plus.net (195.166.129.3) 13.295 ms
5 tun0.ptn-gw01.plus.net (212.159.2.101) 11.254 ms
te9-4.ptn-gw01.plus.net (195.166.129.33) 12.633 ms
tun0.ptn-gw01.plus.net (212.159.2.101) 9.266 ms
6 po2.pcl-gw02.plus.net (195.166.129.43) 9.983 ms
tun0.ptn-gw01.plus.net (212.159.2.101) 9.908 ms
po2.pcl-gw02.plus.net (195.166.129.43) 12.102 ms
7 tun0.pcl-gw01.plus.net (212.159.2.105) 10.484 ms
flowers2.servers.plus.net.uk (212.159.2.98) 9.524 ms
tun0.pcl-gw01.plus.net (212.159.2.105) 8.481 ms
8 195.99.126.138 (195.99.126.138) 9.482 ms
flowers2.servers.plus.net.uk (212.159.2.98) 74.771 ms
195.99.126.138 (195.99.126.138) 9.101 ms
9 195.99.126.96 (195.99.126.96) 10.655 ms
core3-te0-0-0-14.faraday.ukcore.bt.net (213.121.193.160) 9.967 ms
as opposed to
traceroute to 185.31.18.193 (185.31.18.193), 64 hops max, 52 byte packets
1 192.168.29.1 (192.168.29.1) 1.865 ms 1.167 ms 1.473 ms
2 195.166.130.220 (195.166.130.220) 8.184 ms 7.731 ms 8.005 ms
3 link1-central10.pcl-ag07.plus.net (84.93.249.193) 8.102 ms 10.398 ms
link2-central10.pcl-gw02.plus.net (84.93.249.194) 8.776 ms
4 195.99.126.138 (195.99.126.138) 10.135 ms 11.538 ms
195.99.126.182 (195.99.126.182) 11.368 ms
5 core1-te0-3-0-12.ealing.ukcore.bt.net (109.159.254.101) 12.047 ms
host213-121-193-153.ukcore.bt.net (213.121.193.153) 11.876 ms 12.549 ms
6 core2-te0-11-5-0.ealing.ukcore.bt.net (213.121.193.74) 13.255 ms
core1-te0-4-0-5.ealing.ukcore.bt.net (62.172.103.189) 11.596 ms
host213-121-193-230.ukcore.bt.net (213.121.193.230) 11.487 ms
I have just put some entries into my routers /etc/hosts (yay for linux based routers and dnsmasq):
185.31.18.193 i.imgur.com
185.31.18.193 m.imgur.com
185.31.18.193 imgur.com
And seems to be working better for now, until for some reason traffic to that IP starts going through the proxy as well.....or imgur change IPs and I spend a few days shouting at things until I remember those addresses are hard coded in my router
31-01-2016 11:30 PM
01-02-2016 12:16 AM
So bob or who ever what is going on, are you becoming Virgin Media and adding speed caps as you don't have the bandwidth.
01-02-2016 9:08 AM
