imgur.com been slow all week now unreachable
- imgur.com been slow all week now unreachable
28-01-2016 7:59 PM
It's just you. http://imgur.com is up.
http://www.downforeveryoneorjustme.com/imgur.com
Re: imgur.com been slow all week now unreachable
28-01-2016 8:03 PM
28-01-2016 8:22 PM
28-01-2016 8:30 PM
still slow for everyone?
28-01-2016 8:34 PM
I've asked a friend who isn't on plusnet and he says it's fine for him
Then I found this on reddit
https://www.reddit.com/r/AskUK/comments/42npo1/imgur_loading_very_slowly_with_plusnet/
Edit it's suddenly working fine did somebody at Plusnet plug something back in
28-01-2016 8:39 PM
28-01-2016 8:55 PM
Currently on ptn-bng01.
28-01-2016 10:42 PM
Can we have some input on this plusnet please because at them moment i can't fully enjoy my internet package that i pay you for.
oh yeah and i'm on adsl not fibre......
28-01-2016 10:53 PM
Quote from: BillyHunt
Started to work for me at the same time but has since died again.
28-01-2016 11:23 PM
29-01-2016 5:32 AM
This sounds like a DNS server issue, so I would recommend you to change to google DNS.
Or open DNS and make sure you run ipconfig /flushdns under cmd in windows.
Also clear your cache, cookies etc, just to be on the safe side.
Hope this helps.
29-01-2016 6:40 AM
It's most likely to be a Plusnet IWF filter (proxy) issue.
29-01-2016 2:08 PM
Issues like this occur, I've had this issue with Virgin in the past.
It got to the point that I could download, upload and play games.
But browsing was broken, quick dns switch and flush.
And all was well.
A proxy filter wouldn't cause this, as it would block http and https in most cases.
You've to understand about data propagation with dns servers but you can google that.
If you're interested.
I tend to always use google dns, so I never get these issues.
29-01-2016 3:20 PM
Here is a traceroute to TCP port 80 at the time it was working badly, fortunately it had not scrolled off the top of my terminal:
[tt]# traceroute -q 1 -N 1 -T -p 80 imgur.com
traceroute to imgur.com (185.31.19.193), 30 hops max, 52 byte packets
1 gateway (192.168.0.1) 4.347 ms
2 195.166.130.221 (195.166.130.221) 23.178 ms
3 link10-central10.pcl-gw02.plus.net (84.93.249.210) 23.245 ms
4 te9-4.ptn-gw01.plus.net (195.166.129.33) 29.794 ms
5 ae1.pcl-cr02.plus.net (195.166.129.3) 24.754 ms
6 tun0.pcl-gw01.plus.net (212.159.2.105) 26.404 ms
7 tun0.pcl-gw01.plus.net (212.159.2.105) 24.136 ms
8 *
9 *
10 *
11 *
12 *
13 *
14 *
15 *
[/tt]
The tun0 in that traceroute is a giveaway sign that it's going through Plusnet's IWF filter, or at least trying to but failing.
Actually, at the moment, it looks like one of the IP addresses goes through the filter and the other doesn't.
[tt]# traceroute -q 1 -N 1 -T -p 80 185.31.18.193
traceroute to 185.31.18.193 (185.31.18.193), 30 hops max, 52 byte packets
1 gateway (192.168.0.1) 1.772 ms
2 195.166.130.221 (195.166.130.221) 22.960 ms
3 link10-central10.pcl-gw02.plus.net (84.93.249.210) 22.763 ms
4 ae1.pcl-cr02.plus.net (195.166.129.3) 24.058 ms
5 te9-4.ptn-gw01.plus.net (195.166.129.33) 22.319 ms
6 tun0.ptn-gw01.plus.net (212.159.2.101) 22.716 ms
7 185.31.18.193 (185.31.18.193) 23.281 ms
# traceroute -q 1 -N 1 -T -p 80 185.31.19.193
traceroute to 185.31.19.193 (185.31.19.193), 30 hops max, 52 byte packets
1 gateway (192.168.0.1) 2.535 ms
2 195.166.130.221 (195.166.130.221) 22.978 ms
3 link10-central10.pcl-gw02.plus.net (84.93.249.210) 23.509 ms
4 195.99.126.182 (195.99.126.182) 27.012 ms
5 core1-te0-3-0-12.ilford.ukcore.bt.net (109.159.254.125) 27.623 ms
6 peer5-te0-10-0-11.telehouse.ukcore.bt.net (109.159.255.89) 26.256 ms
7 *
8 ldn-b3-link.telia.net (213.248.67.97) 24.943 ms
9 185.31.19.193 (185.31.19.193) 24.435 ms[/tt]
29-01-2016 3:46 PM
