iPlayer Buffering in Hampshire
InterZoom
Are there currently congestion/capacity problems in the Petersfield area?
Visiting Plusnet-ified friends and iPlayer cut out 5 or 6 times in the course of a 1 hour programme yesterday evening.
All possible on-premises causes investigated and eliminated. Seems to be very much T.O.D. dependent and an ongoing issue.
Good connection according to the Plusnet Hub One:
3. Firmware version: Software version 4.7.5.1.83.8.263 Last updated Unknown
6. Data rate: 19999 / 77705
7. Maximum data rate: 24389 / 77694
8. Noise margin: 15.1 / 5.9
9. Line attenuation: 9.4 / 9.8
10. Signal attenuation: 9.4 / 9.9
23. Modulation: G.993.2 Annex B
24. Software variant: AA
Can Plusnet staff shed any light?...
5 REPLIES 5
Fixes: 107
Re: iPlayer Buffering in Hampshire
@InterZoom
How is the tv connected to the router? Ethernet cable or wireless?
If wireless tnen that is most likely your problem.
If using powerline devices then you need to replace them temporarily with an Ethernet cable as these can also be intermittently problematic..
InterZoom
The connection is ethernet.
Testing it at the moment (when, presumably, there's little demand,) there's no problem...
Fixes: 40
Hi there @InterZoom, can you send me over a PM with the username of the account relates to (or full address and postcode if you're unsure) so we can take a look at this.
Once you have sent the PM, please just let us know via this post Smiley
 Lauren Barry
InterZoom
Hi @LaurenB
Thanks for replying and taking a look. I've sent you a PM with that and some other details just now  Smiley
InterZoom
It's definitely network congestion (query packet loss). General internet browsing is slow as hell just now: nearly 8 seconds to load the Guardian homepage, as measured by both Chrome and Safari developper tools on 2 different computers. That's not normal.
Will leave it with you, PN...   🐢
