iPhones and tv keep dropping wi-fi
- iPhones and tv keep dropping wi-fi
a month ago
Re: iPhones and tv keep dropping wi-fi
a month ago - last edited a month ago
Basically the Hub One is a load of junk, consequently many of us get a BT Smarthub 6, which are cheap from an auction site and use that intead.
The first thing to try is separating the 2.4 and 5 GHz bands, see https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840. Try each band in turn and use the best. If that doesn't work you could join this thread https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/m-p/1696363#M15510
The noise is a feature of some of these hubs. It can be improved if you switch off the 5GHz band.
a month ago
a month ago
I can only guess that being a budget provider they supply a budget hub that meets the needs of most subscibers. They have been promising a firmware uodate for I would guess a year now.
About £20 will solve the problem as previously advised in as far as you can get a quiet hub with better WiFi .
a month ago
