http://speedtest.btwholesale.com/ giving wrong results
- Re: http://speedtest.btwholesale.com/ giving wrong...
28-11-2016 8:17 PM
checked with TBB and speedtest.net's testers but http://speedtest.btwholesale.com/ is currently showing half speed on the download test
Re: http://speedtest.btwholesale.com/ giving wrong results
28-11-2016 8:24 PM
29-11-2016 12:48 AM
it started reporting correct download speed after 11pm but now its showing upload is halved
Download speedachieved during the test was - 42.59 Mbps
For your connection, the acceptable range of speedsis 31.21 Mbps-44.59 Mbps .
Additional Information:
IP Profile for your line is - 44.59 Mbps
Upload Speed
5.25 Mbps
0 Mbps 20 Mbps
Max Achievable Speed
Upload speed achieved during the test was - 5.25Mbps
should be 10 which the other testers report
29-11-2016 2:17 AM - edited 29-11-2016 2:18 AM
Im finding the speed test at http://www.thinkbroadband.com/speedtest.html to be inaccurate / jittery, its said that speedtest sites requiring the adobe flash plug in are not as accurate as the HTML5 speedtesters such as http://speedof.me/
29-11-2016 12:18 PM
@shylok wrote:
...its said that speedtest sites requiring the adobe flash plug in are not as accurate as the HTML5 speedtesters
By whom? No doubt those promoting their own HTML5 testers.
I find that site particularly inaccurate.
29-11-2016 3:20 PM
According to what i read on cnet who compared speedtesters here
"Many experts claim HTML5-based speed tests are more accurate than tests that use Java and Adobe Flash. Others point out that multithread tests such as those used by Ookla (Speedtest.net and branded by many ISPs) don't represent real-world network traffic as well as single-thread tests"
Theres a review of HTML5 speedtesters here
"Speedof.me came closest to the actual speed of the Internet connection. While it lacks options to change servers, it was the most accurate HTML5 Internet speed testing service.
Your mileage may vary depending on your location in the world though."
29-11-2016 3:50 PM - edited 29-11-2016 4:15 PM
Cnet? I wouldn't trust them to tell me which day it was!
If you read the article you linked to they suggest HTML5 testers are the best but then go on to say Ookla testers are more accurate
If you want to try something which doesn't rely on HTML5 or Flash I can recommend JD's Auto Speed Tester.
29-11-2016 9:39 PM
thought I was already on the New improved network, but guess not as now on vastly different routing than I have had previously. Plus the pleasure of getting packet loss, which I have not had in months which just caps off BTspeedtester not working while trying to find a recordable fault for support monkeys that do live chats
Best Effort Test: -provides background information.
Download Speed | |
22.26 Mbps |
0 Mbps | 44.59 Mbps Max Achievable Speed |
Download speedachieved during the test was - 22.26 Mbps For your connection, the acceptable range of speedsis 31.21 Mbps-44.59 Mbps . Additional Information: IP Profile for your line is - 44.59 Mbps |
Upload Speed | |
9.07 Mbps |
0 Mbps | 20 Mbps Max Achievable Speed |
Upload speed achieved during the test was - 9.07Mbps Additional Information: Upstream Rate IP profile on your line is - 20 Mbps |
