high ping on wired/broadband randomly going limited
dontdisobey
Since i'm a PC gamer, ping is important to be low and stable which is why i use wired instead of wireless connection.I'ts been fine for nearly year, however recently at random times my ping will increase up to 400 for about 10 minutes and then goes back down again. Also, the broadband randomly goes limited for a while then goes back to connected (not just for my PC but all devices). This is slowly ruining my gaming/online experience so i need to know whats causing the issues ASAP
Thanks in advanced Smiley
TheHorseman
Re: high ping on wired/broadband randomly going limited
This is my ThinkBroadband latency/packetloss graph for today.
http://www.thinkbroadband.com/ping/share/963300d1dc02729fe7f4916e290db263-31-07-2016.html
rongtw
Fixes: 12
Are you using the PN router ?
also what does it say here ? http://usertools.plus.net/@gateway/
dontdisobey
Yes i'm using the PN router
You are currently connected to gateway pcl-bng02.
This is located in City Lifeline House.
rongtw
Fixes: 12
Unfortunately PN gateways BNG are fairly bad for gaming , Try rebooting router from the router web page if you lucky you may get a better connection Smiley
dontdisobey
I rebooted my router and so far my ping and broadband is stable Smiley Thanks for the help
