hi internet droping out
masterreflector
new to plus net though I give it a bash but I have one problem with it the internet keeps dropping out between 6pm-10pm I understand get slow at certain times but it should not drop out not really I mean I use to use virgin media and I never had drop out then so why with plus net  Sad
Fixes: 167
Re: hi internet droping out
Below is a visual image of your disconnections. As you mentioned there are quite a few showing up, mainly in the evenings. Is there anything local that might happen around the times the drops occur? Heating coming on, street lights turning on etc? If they continue I'd run through https://faults.plus.net
 Chris Parr
 Plusnet Staff
masterreflector
thank you for the help and support  Grin
Fixes: 167
No problem. I see you've been through the faults checker now, the ticket will be picked up by our support team here and they'll do some more tests on the line.
 Chris Parr
 Plusnet Staff
