hey there
flearider
hey there
ok just came over from ee after 6 yrs ..
now yes it's still day one but the speeds are lower Sad  boo hoo I know
it will take a few days to settle down  but the upload is only around 7mb yikes !!!
just to let you know on ee I was doing 66mb upload and 18mb download ..
we will se how it go's .. but lets hope it sorts itself out soon as I'm having major lag issues as well
4 gamers in the house all wired  wifi is for phones Smiley
Browni
Aspiring Hero
Fixes: 45
Re: hey there
Router stats? Troubleshooting->helpdesk
Expected speeds?
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
Fixes: 194
Re: hey there
Sorry to hear this.
Our tests aren't showing issues and your upload speed is syncing at the maximum speed as shown below
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 58.7 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 425.0
Upstream Rate Assessment Very Good
Downstream Rate Assessment Low
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-67M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2018-06-20T19:30:00
Parameters MIN MAX AVG
Down Stream Line Rate 58.4 Mbps 65.7 Mbps 65.2 Mbps
Up Stream Line Rate 20.0 Mbps 20.0 Mbps 20.0 Mbps
Up Time 0.0 Sec 900.0 Sec 894.6 Sec
Retrains 0.0 3.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2018-07-03T19:01:25.948+01:00 2018-07-03T19:16:25.948+01:00
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
Are you testing over a wired or wireless connection?
 Matthew Wheeler
flearider
Re: hey there
wired the 3 TV's and phones are wifi
but the 4 pc's are wired we all game from dota 2 to civ6 Smiley
strange .. ? I might just plug the draytek in and see if it's the router
http://www.speedtest.net/result/7442795734
hmmm
think that's a bit out it's on the opposite corner diagonally across the street
Fixes: 412
Re: hey there
No worries, keep us posted. If you're still experiencing speed problems, Can you run a BT speedtest at http://www.speedtest.btwholesale.com using a wired connection, completing the further diagnostics at the end? This will store the result on the supplier system and will help us in reporting a fault to our suppliers.
flearider
Re: hey there
after leaving it a few days it's sorted itself out
http://www.speedtest.net/result/7449925829
and that's with 2 other people using net
thx
Fixes: 4
Re: hey there
Thanks for letting us know. Smiley
 Tony T
