help with new fibre install
St3
Aspiring Champion
Fixes: 5
hope u dont mind Wink
My bro just got fibre installed and his getting these speeds
i did message adam walker but i think chris is now sorting this.
34 REPLIES 34
Chris
Legend
Fixes: 169
Re: adam... ive message u
I'll take a look St3, drop me his username in a PM.
St3
Aspiring Champion
Fixes: 5
Re: help with new fibre install
Hmm its not hitting the 70 mark like its supposed too
Chris
Legend
Fixes: 169
Hmm, I'm getting an error when running a line test. Let me speak to someone and see what they recommend.
St3
Aspiring Champion
Fixes: 5
yep ok
Chris
Legend
Fixes: 169
The line check is showing quite a lot of errors on the line, so they are most likely causing the slower speeds. Can you go through the faults checker at https://faults.plus.net and we'll get this raised, it's likely to need an engineer visit but we'll confirm that before anything gets booked.
St3
Aspiring Champion
Fixes: 5
Could it have anything to do with the modem not being connected directly to the master socket and the filters are all still connected to the sockets, the kellys engineer said the router didnt need to be put on the master socket and he said the filters which i used for the adsl didnt need to be removed either the guy also did not change any sockers he just plugged bt modem in and left.
Now when i got my fibre installed the guy that came to mine said it had to be connected to the master socket and i had to remove all the filters, kinda confussing when u got 2 people telling you different things
So im wondering could this be the issue?
MatthewWheeler
Fixes: 479
That will most likely be the cause.
It does sound like the engineer did the bare minimum.
If you can get your brother to raise a fault we'll get a engineer out to sort this out properly.
 Matthew Wheeler
St3
Aspiring Champion
Fixes: 5
ok ive raised a fault, i tried to bypass the router and use the modem directly but that never improved the speed. Ive ran a few speedtests and its up and down but never goes over 20 meg and the upload speeds are up and down too.
What should the engineer actully do when he comes to install fibre ?
Chris
Legend
Fixes: 169
The engineer should check the line, make the relevant changes at the cab, change the master socket and plug in the modem.
We'll get the fault looked at asap. Can you let us know what the availability for an engineer would be so we can get this booked if needed?
St3
Aspiring Champion
Fixes: 5
give me a date and time and ill be there at his house... like i am today :)P
Chris
Legend
Fixes: 169
Awesome, we'll get back to you asap.
St3
Aspiring Champion
Fixes: 5
no worries thanks for your help
Chris
Legend
Fixes: 169
We need to wait for a response from the automated testing, we'll check again before the end of the day today but it may be that we have to wait until tomorrow.
St3
Aspiring Champion
Fixes: 5
yep no worries i guess the main thing is he still has a connection for now.
