half speed
goatty2
half speed
well a good start to new contract
1. Best Effort Test: -provides background information.
  Download Speed
  17.34 Mbps
0 Mbps 33.85 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 17.34 Mbps
 For your connection, the acceptable range of speedsis 20 Mbps-33.85 Mbps .
 Additional Information:
 IP Profile for your line is - 33.85 Mbps
  Upload Speed
  3.26 Mbps
0 Mbps 10 Mbps
Upload speed achieved during the test was - 3.26Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Please visit the FAQ if you are unable to understand the test results.
8 REPLIES 8
goatty2
Re: half speed
just done test on speedtest.net and speed gone back or is there a problem with BT test
http://www.speedtest.net/my-result/6944469570
newagetraveller
Re: half speed
I also wonder if there is a problem with the BT speed test.
It shows varying results for my speeds, both up and down. In contrast both Ookla Speedtest and Thinkbroadband checkers show consistently good results when BT's are poor and advising a fault.
goatty2
Re: half speed
must be BT fault as thinkbroadband test
https://www.thinkbroadband.com/speedtest/1515346651484002455
newagetraveller
Re: half speed
http://www.speedtest.net/my-result/6944510555
Ookla result just now and BT reports 10.3 down and 5.59 up.
goatty2
Re: half speed
nice speed there is no chance of me getting your speed
tried another test on BT and it said download now 15mb
LaurenB
Fixes: 131
Re: half speed
Hi @goatty2 sorry to hear you are having issues.
Testing isn't detecting the cause of the speed issues. Could raise the fault here and let us know when you have completed it.
 Lauren Barry
goatty2
Re: half speed
I think it is BT testing that is the problem as other people's speed test have same problem
speed test on other sites show twice the speed as BT
goatty2
Re: half speed
think I have sorted the problem with BT speed test
I have tested it on 4 different browsers and firefox 58.0b14 (64-bit) is the only one to do half speed
