gea test
williamsben16
gea test
can you do gea test please speed really slow
1 REPLY
Fixes: 453
Re: gea test
Hi there. Here you go:
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 14.8 Mbps
Upstream Speed 5.8 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 1045.8
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-27.4M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
It certainly is slow.
If you've tried the checks here I'd raise a fault to us here.
