gea test
- gea test
gea test
13-06-2018 5:05 PM
can you do gea test please speed really slow
Message 1 of 2
(376 Views)
1 REPLY 1
Re: gea test
13-06-2018 5:20 PM - edited 13-06-2018 5:21 PM
Hi there. Here you go:
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 14.8 Mbps |
Upstream Speed | 5.8 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 1045.8 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Reasonable |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-27.4M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off |
It certainly is slow.
If you've tried the checks here I'd raise a fault to us here.
Message 2 of 2
(368 Views)
