gea test to see how things are going
iangilf
Re: gea test to see how things are going
hi dean ok for now m8 cheers but the drops are annoying weird as most of the time is fine now but still dropping so something not totally right
are u seeing any errors your side at all dean ?
uptime 0 days 23 hours 0 minutes
  Upstream Downstream
Current Rate (kbps) 20000 79987
Max Rate (kbps) 31283 86303
SNR Margin (dB) 12.5 7.4
Line Attenuation (dB) 18.7 9.5
Errors (pkts) 76 174
MatthewWheeler
Fixes: 480
There are a few errors but nothing majorly concerning.
If the drops continue we'd recommend raising a fault here
 Matthew Wheeler
iangilf
ok m8 ta
andytay
I have done another speed test and its worse. I have attached pics from ookla and BT, also my ip profile seems low?
andytay
Here is the ookla test
MatthewWheeler
Fixes: 480
@andytay Sorry to hear this.
It looks like your sync speeds have dropped but our tests aren't showing any cause for this.
I'd recommend raising a fault here so we can investigate further
 Matthew Wheeler
iangilf
1. Product name: Plusnet Hub
2. Serial number: +081441+NQ54605283
3. Firmware version: Software version 4.7.5.1.83.8.259 Last updated 19/07/18
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 03:12:50
6. Data rate: 20000 / 79995
7. Maximum data rate: 30840 / 86195
8. Noise margin: 12.4 / 7.6
9. Line attenuation: 17.1 / 14.0
10. Signal attenuation: 17.0 / 14.0
im still getting drops they fixed the cable i was probably on a decent port before but now im probably not getting on my nerves all this now
MasterOfReality
Fixes: 57
Hi @iangilf
Thanks for getting back to us.
I've looked into these drops, are we are only seeing one drop in the last 34ish hours - have you noticed more than this at your end?
Can you confirm you've done what Sammy suggested and connected to you internal Test Socket?
Thanks,
MoR
iangilf
Yep did that ages ago and was no difference with the faceplate on and yes I've seen drop outs still mate
deank
Fixes: 14
Below is your connection log as we can see from our side. If you are still experiencing issues I would recommend raising a fault here.
iangilf
hi can u make sure im still on the right profile please for my line syncing at 80 meg but threwput isnt as high as what it should be so it seems thanks alot and line seems far better and stabler now Smiley
thanks
adamwalker
Fixes: 221
Hi there, sure. I've just updated the profile in line with what you've mentioned.
 Adam Walker
iangilf
just had a few drop outs all in a row ?
RandallFlagg
Fixes: 75
Hi @iangilf,
I've copied the visual of your connection for the last seven days below.
Although I can see two drops in quick succession yesterday the connection has been stable since.
Could you keep an eye on this and let us know whether the drops reoccur/get worse?
Best wishes,
Dave
iangilf
ok thanks it was more than 2 so thats strange that it only flagged 2 i will keep an eye on it thanks
