gea test to see how things are going
iangilf
hi can i request a full gea test to see how my lines behaving now thankyou
166 REPLIES 166
Jubby
All Star
Fixes: 31
Re: gea test to see how things are going
Hi @iangilf
I have performed a GEA service tests and the results are below.
GEA Test Detail
Circuit ID NA Service ID BBEU
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 80.0 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Estimated Line Length In Metres 358.2
Upstream Rate Assessment Very Good
Interference Pattern Regular Interference Observed Daily
Service Impact Retrains Observed
Interference Duration Longest Occurrence From 16:30 to 16:45
Interference Location Unknown
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2018-08-08T12:15:00
Parameters MIN MAX AVG
Down Stream Line Rate 74.8 Mbps 79.9 Mbps 79.6 Mbps
Up Stream Line Rate 20.0 Mbps 20.0 Mbps 20.0 Mbps
Up Time 520.0 Sec 900.0 Sec 898.4 Sec
Retrains 0.0 3.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2018-08-20T08:47:20.118+01:00 2018-08-20T09:02:20.118+01:00
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
Our testing shows your connection is stable and is operating within the estimated speed. Are you currently experiencing any issues with your service?
 Lewis G
 Infrastructure Operations Professional
andytay
Could someone do a GEA test for me please as i dont feel im getting the upload/download i am supposed to get?
Thank you!
EmilyD
Fixes: 117
Hi @andytay,
I've run a GEA test on your line and the test hasn't picked up any issues and indicates that your line is currently syncing at the full 40mbps down and 10mbps up. Please let us know if you're still experiencing problems with the connection on your side.
GEA Test Detail
Circuit ID NA Service ID BBEUXXXXXXXXX
Test Outcome Pass
Sync Status In Sync
Downstream Speed 40.0 Mbps
Upstream Speed 10.0 Mbps
Cross Talk Not Detected
Estimated Line Length In Metres 463.2
Technology VDSL
Profile Name 0.128M-40M Downstream 3dB, Retransmission Low - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2018-08-08T10:15:00
Down Stream Line Rate 39.9 Mbps 39.9 Mbps 39.9 Mbps
Up Stream Line Rate 9.9 Mbps 9.9 Mbps 9.9 Mbps
Up Time 0.0 Sec 900.0 Sec 876.8 Sec
Retrains 0.0 1.0 0.0
Start Time Stamp 2018-08-21T08:31:49Z 2018-08-21T08:46:49Z
Ingress Code Violation 0 1
Egress Code Violation 26 0
Errored Seconds 11 0
 Emily D
andytay
Hi Emily,
Thank you for running the test for me, The reason i asked is because my upload seems slower than normal.
I have attached a pic of the speed test i did.
RealAleMadrid
Aspiring Hero
Fixes: 59
The BT speed test has been changed recently and they have not got it working properly yet. Particularly the upload speed reported is much lower than the actual speed. Try some other speed testers. Smiley
andytay
I have done another test nothing was connected to my router only my pc and my speed is worse!
adamwalker
Fixes: 221
Cheers for getting back to us, were you connecting over WiFi or Ethernet when you ran that test? - Adam
 Adam Walker
andytay
Hi Adam,
I did the tests over a wired connection.
deank
Fixes: 14
Hi @andytay
Can you confirm that this is connected to the main socket in your property and not an extension? Looking at the tests from our side everything is looking fine. Can you please follow the steps to raise this at http://faults.plus.net and let us know when you have done this so we can escalate this for you.
andytay
Hi
I can confirm this is connected to the main BT-Openreach master socket and not on an extension.
SammyM
Fixes: 96
Hello @andytay,
Thanks for getting in touch. I have a checked your connection and there definitely seems to be something out of place somewhere as we can see more errors on your line than we would like. Although our tests aren't picking up exactly what's causing the issue so we will have to do some troubleshooting to start ruling things out.
I'd recommend starting with basic checks here,
And if that doesn't help the next thing would be to rule your internal wiring out by plugging the connection into your test socket which is under the faceplate of your master socket and seeing if the drops stop. This rules out internal wiring, face plates and extension sockets as being the cause. How to locate the test socket and set your connection into it can be found here:
https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
Once here please run a speed test over a wired connection  and if the speed is still below estimates
Sammy
Moderator's note by Dick (Strat): Font style corrected.
 Sammy M - Sheffield Team
iangilf
uptime
3 days 2 hours 21 minutes
been much better recently which is good
are them errors ok over a 3 day period ?
  Upstream Downstream
Current Rate (kbps) 20000 79987
Max Rate (kbps) 31303 86279
SNR Margin (dB) 12.6 7.4
Line Attenuation (dB) 18.8 9.6
Errors (pkts) 76 2558
iangilf
Lol after saying that the line dropped at least 4 times in a row I don't believe it
deank
Fixes: 14
I can see that it has held up since the 4 drops and we have seen no further drops on the line. How is the performance holding up from your side now?
