gateway woes
- Re: gateway woes
gateway woes
22-01-2015 12:46 PM
Is there a balancing issue as the stats on the graph seem to show more users on this gateway than the others?
http://www.plus.net/support/service/network_performance/broadband_bandwidth_usage.shtml
Re: gateway woes
22-01-2015 1:47 PM
Something's obviously broken
Re: gateway woes
22-01-2015 2:05 PM
Is there someone from Plusnet who could maybe take a look?
Re: gateway woes
22-01-2015 2:08 PM
Re: gateway woes
22-01-2015 2:10 PM
Re: gateway woes
22-01-2015 2:16 PM
Re: gateway woes
22-01-2015 4:13 PM
I was a bit suspicious of the gateway as that seemed to be the common factor in change of latency and the interruptions on netflix.
Re: gateway woes
27-01-2015 9:30 PM
Thanks for the help and advice!
Re: gateway woes
28-01-2015 8:49 AM
A couple of days ago i was virtually at the top of the list (least connected) and today I'm virtually at the bottom?
After a Speedtest, speeds are still consistent though, but pings have increased a bit.
Re: gateway woes
28-01-2015 12:34 PM
Will check again tonight if the problem still the same!
Re: gateway woes
30-01-2015 11:26 PM
