gateway changes
- gateway changes
- « Previous
- 1
- 2
- Next »
Re: gateway changes
09-10-2014 7:05 PM
Re: gateway changes
10-10-2014 6:03 AM
Re: gateway changes
10-10-2014 6:21 AM
Re: gateway changes
10-10-2014 7:48 AM
Re: gateway changes
10-10-2014 10:44 AM
Your connection has continued to drop-out intermittently, unfortunately. Thank you for raising the broadband troubleshooter, a ticket has now been raised with our faults team and they will be back in touch within the next 72 hours after they have completed testing of your connection.
Re: gateway changes
11-10-2014 7:27 AM
Re: gateway changes
11-10-2014 12:14 PM
Re: gateway changes
11-10-2014 2:10 PM
Re: gateway changes
11-10-2014 6:47 PM
Internet connected] IP address: 84.51, Saturday, Oct 11,2014 16:51:35
[Internet disconnected] Saturday, Oct 11,2014 16:50:09
[Internet connected] IP address: 172.20., Saturday, Oct 11,2014 16:40:09
[Internet disconnected] Saturday, Oct 11,2014 16:39:56
[Internet connected] IP address: 172.20., Saturday, Oct 11,2014 16:29:57
[Internet disconnected] Saturday, Oct 11,2014 16:29:01
[Internet connected] IP address: 172.20., Saturday, Oct 11,2014 16:19:01
[Internet disconnected] Saturday, Oct 11,2014 16:18:46
[Internet connected] IP address: 172.20., Saturday, Oct 11,2014 16:08:46
[Internet disconnected] Saturday, Oct 11,2014 16:08:34
I am posting here because i cant post on My questions as i will go to BACK of list .
PS today at 12 ish i powered off Bt modem & netgear router
i also have just checked router is set to Always ON ! and not to turn off when idle
Re: gateway changes
13-10-2014 1:30 PM
Sorry to see there's a dropping connection issue now, rest assured this won't be related to the gateways but it's quite normal to see a change from one to the other when disconnections occur.
Bear with us and the faults team will be getting back to you on ticket 92837622 soon.
If you see any speed issues or more specifically variations in speed between gateways please after this is fixed please head here:
http://community.plus.net/forum/index.php/topic,132509.16.html
Re: gateway changes
13-10-2014 6:54 PM
Your connection was really bad around 6pm on Saturday. It's possible it was something to do with the outage. However, since then it seems to have settled down. If it continues to drop, I recommend raising a fault as rongtw has.
Quote from: goatty2 Hi Luke S
Had 5 gateway change on 13/08/14
and no change in speed
http://www.speedtest.net/my-result/3689815774
then the speed slowly went down till
http://www.speedtest.net/result/3731477331.png
did a ticket and was told after testing there was nothing wrong.
it stopped at that rate till the 7th October and then shot up
http://www.thinkbroadband.com/speedtest/button/141270467136921551317.png
just have to wait and see if ispeed goes down again
Re: gateway changes
18-11-2014 10:32 AM
http://www.speedtest.net/result/3918325196.png
http://www.thinkbroadband.com/speedtest/button/141630469216837379093.png
speed has eventually gone back to what it was ages ago
did bt test just to check
Download speedachieved during the test was - 40.23 Mbps
For your connection, the acceptable range of speedsis 29.62 Mbps-42.31 Mbps .
Additional Information:
IP Profile for your line is - 42.31 Mbps
Upload speed achieved during the test was - 3.79Mbps
Re: gateway changes
18-11-2014 5:48 PM
Those speeds are looking better than some of the previous ones in this thread, let us know if you've got any questions we can help with.
- « Previous
- 1
- 2
- Next »
