gateway changes
goatty2
gateway changes
anyone else having problem with gateway changes I have had 6 since 12:50 today
had one change on the 7th and one on the 5th of this month
gone about 18 days without a change before this
rongtw
Fixes: 12
Re: gateway changes
yup the other day i was auto swapped to a BNG ,,,,  but weird since forum change my post has disappeared  Embarrassed
rongtw
Fixes: 12
Re: gateway changes
and 2 more times  Angry Angry  last night at 22.00 kicked off BNG01 , and now 08.00 just lost connection now on  ptn-ag02.  Huh  come on PN what going on
Re: gateway changes
None of the ping graphs on the Community page are showing any issues.
More likely, you're losing sync with the cabinet.
rongtw
Fixes: 12
Re: gateway changes
So is that my router , causing this ?
LukeS
Re: gateway changes
Hi goatty2,
Please see your radius log below, you'll notice a similar amount of disconnections to the changes in gateways you've mentioned. We have been doing some maintenance but it's unlikely to have caused that many drops. Have you noticed any change in the download or upload speed?
Maintenance - http://usertools.plus.net/status/archive/1412777996.htm
<img src="http://community.plus.net/visualradius/generated/image14128427257210.png"/>
Re: gateway changes
Quote from: rongtw
Not quite sure.
Is your IP Profile unchanged?
LukeS
Re: gateway changes
@rongtw
As discussed, the drops seem fairly random, have you turned off your equipment at all? At the moment, I think the best thing to do is monitor the connection but if it continues to drop we'll run some further diagnostics.
<img src="http://community.plus.net/visualradius/generated/image14128437179795.png"/>
rongtw
Fixes: 12
Re: gateway changes
Cheers for your call Luke , have changed details now  Wink
PS my router is on 24/7
LukeS
Re: gateway changes
I've just tested the line and everything seems fine apart from :-
"The firmware loaded onto this modem is not current. Please instruct your customer to power down and then power up the modem again to load the latest firmware version"
When you get chance, power down the modem for a few minutes and then monitor for a couple of days.
rongtw
Fixes: 12
Re: gateway changes
my current  Firmware Version
V1.0.2.68_60.0.93
i have a netgear WNR1000v3
Fixes: 162
Re: gateway changes
I think Luke might have been referring to the Openreach modem, rather than your router/
 Chris Parr
 Plusnet Staff
rongtw
Fixes: 12
Re: gateway changes
ooooops DOH  Cheesy
ghos7em1
Re: gateway changes
whats the latest firmware for openreach modem?
goatty2
Re: gateway changes
Hi Luke S
Had 5 gateway change on  13/08/14
and no change in speed
http://www.speedtest.net/my-result/3689815774
then the speed slowly went down till
http://www.speedtest.net/result/3731477331.png
did a ticket and was told after testing there was nothing wrong.
it stopped at that rate till the 7th October and then shot up
http://www.thinkbroadband.com/speedtest/button/141270467136921551317.png
just have to wait and see if ispeed goes down again
