gateway changes
- Re: gateway changes
gateway changes
08-10-2014 6:52 PM
had one change on the 7th and one on the 5th of this month
gone about 18 days without a change before this
Re: gateway changes
08-10-2014 10:04 PM
Re: gateway changes
09-10-2014 8:03 AM
Re: gateway changes
09-10-2014 8:26 AM
More likely, you're losing sync with the cabinet.
Re: gateway changes
09-10-2014 8:43 AM
Re: gateway changes
09-10-2014 9:22 AM
Please see your radius log below, you'll notice a similar amount of disconnections to the changes in gateways you've mentioned. We have been doing some maintenance but it's unlikely to have caused that many drops. Have you noticed any change in the download or upload speed?
Maintenance - http://usertools.plus.net/status/archive/1412777996.htm
<img src="http://community.plus.net/visualradius/generated/image14128427257210.png"/>
Re: gateway changes
09-10-2014 9:26 AM
Quote from: rongtw So is that my router , causing this ?
Not quite sure.
Is your IP Profile unchanged?
Re: gateway changes
09-10-2014 9:37 AM
As discussed, the drops seem fairly random, have you turned off your equipment at all? At the moment, I think the best thing to do is monitor the connection but if it continues to drop we'll run some further diagnostics.
<img src="http://community.plus.net/visualradius/generated/image14128437179795.png"/>
Re: gateway changes
09-10-2014 9:40 AM
PS my router is on 24/7
Re: gateway changes
09-10-2014 9:57 AM
"The firmware loaded onto this modem is not current. Please instruct your customer to power down and then power up the modem again to load the latest firmware version"
When you get chance, power down the modem for a few minutes and then monitor for a couple of days.
Re: gateway changes
09-10-2014 10:00 AM
V1.0.2.68_60.0.93
i have a netgear WNR1000v3
Re: gateway changes
09-10-2014 10:02 AM
Re: gateway changes
09-10-2014 10:08 AM
Re: gateway changes
09-10-2014 1:10 PM
Re: gateway changes
09-10-2014 6:22 PM
Had 5 gateway change on 13/08/14
and no change in speed
http://www.speedtest.net/my-result/3689815774
then the speed slowly went down till
http://www.speedtest.net/result/3731477331.png
did a ticket and was told after testing there was nothing wrong.
it stopped at that rate till the 7th October and then shot up
http://www.thinkbroadband.com/speedtest/button/141270467136921551317.png
just have to wait and see if ispeed goes down again
