fibre upgrade.
Porksley
fibre upgrade.
I've just upgraded to fibre. I got an email from PN to tell me my service was now active. I've done a speed test and there is absolutely no difference to my speed. Still getting 3.2 mps. I can't test it using a cable rather than the wireless as I use a chromebook and there is no cable connection. Any clues?
Porksley
Re: fibre upgrade.
PS. I was told that it was ok to set my new router up before the service changed to fibre as it would automatically detect the changeover.
maranello
Re: fibre upgrade.
If today is your scheduled upgrade, it could take anytime up until midnight for the changeover to occur.
My other car isn't a Ferrari
Porksley
Re: fibre upgrade.
Yeh, but I've had an email this morning saying it's completed.
maranello
Re: fibre upgrade.
Unfortunately that is how they do things at Plusnet. It wouldn't be difficult to change the wording of the email, which is usually sent out in the early morning on the day the upgrade is due, but there doesn't seem to any incentive despite the frequent similar comments I've seen on this forum.
Porksley
Re: fibre upgrade.
Thanks. I'll leave it for now then before I get in touch with them about it and see if anything miraculous happens.
maranello
Re: fibre upgrade.
Grin
Hope it all works out for you.
Fixes: 167
Re: fibre upgrade.
I've just double checked and the order is still in place for today.
 Chris Parr
 Plusnet Staff
Porksley
Re: fibre upgrade.
Came on this afternoon. Estimated speed was 34 - 38 mbs and I'm getting 50mbs. Happy bunny!
Fixes: 238
Re: fibre upgrade.
Glad to hear it!
 Matthew Wheeler
