fibre - minimum gauranteed speed
JohnofYork
according to Plusnet ...
Your broadband service
  • Product: Unlimited Fibre
  • Estimated Download Range: 15 - 23Mbps
  • Estimated Upload Range: 2.5 - 4Mbps
  • Minimum Guaranteed Speed: 13.5Mbps
  • Current Line Speed (Download): 12.8Mbps
according to speedtest.btwholesale.com:
Advance Test
Download Test
Download speed achieved during the test was 11.81 Mbps
For your connection, the acceptable range of speeds is 9.04 - 12.91 Mbps
IP Profile for your line is 12.91 Mbps
Upload Test
Upload speed achieved during the test was 1.23 Mbps
IP Profile for your line is 10 Mbps
how close should the match up be? as far as I'm aware, we've never achieved the dizzy rate oif 13.5Mbps ever ...
1 REPLY 1
Terranova667
Fixes: 5
Re: fibre - minimum gauranteed speed
You should at least match the minimum Guaranteed Speed that's what it's for that your connection is at a minimum that speed, if not then an Engineer should be sent to get the speed to at least match it, more if possible.
I would report a fault and get it looked at.
you can report here https://faults.plus.net/
