fibre connection
- fibre connection
fibre connection
25-01-2015 4:46 PM
My fibre broadband router will be connected using the phone line in my lounge. Will I be able to easily receive a signal in all the other rooms in my small flat? Its important as I use different rooms all the time. Many thanks. ☺
Message 1 of 5
(733 Views)
4 REPLIES 4
Re: fibre connection
25-01-2015 4:57 PM
I don't think you will have any problems, i have a medium sized house and i get good signal on all floors from the plusnet supplied router
Message 2 of 5
(395 Views)
25-01-2015 4:58 PM
Hi
Yes, you should be able to use it fine.
To get the best signal, you'll probably need to do some fine tuning (playing around with the wireless channels and also positioning the router).
Message 3 of 5
(395 Views)
25-01-2015 5:17 PM
Thank you so much.. Fingers crossed It all goes smoothly in a couple of weeks..
Message 4 of 5
(395 Views)
26-01-2015 12:05 PM
Message 5 of 5
(395 Views)
