fibre connection keeps disconnecting
karimoum
recently my router keeps disconnecting from the internet. It has happened twice today and a few times since the I owned this router which started over a week ago.
I need to double check that the login settings are correct, the router is a tp-link archer c2, it's connecting to the internet behind the bt openreach modem,
Are the connection settings correct?
Re: fibre connection keeps disconnecting
I could be wrong but I think the 'Max Idle Time' should be set to 0 (zero).
Call me 'w23'
karimoum
the max idle time is a sub-option for connect manually.
But it's worth a shot. I have changed it to connect manually and set max idle time to 0.
