fibre broadband unlimited is worse than my old supplier
- fibre broadband unlimited is worse than my old sup...
09-06-2017 10:54 AM
I've been a customer approx 5/6 weeks, during that time, the speed has been nowhere near the advertised speeds, and drops off. Not quite the fantastic package that I was kind of expecting and makes me wonder if I should have stayed with Sky on their basic broadband as this is not better, in fact it's worse!
Re: fibre broadband unlimited is worse than my old supplier
09-06-2017 1:27 PM
Thanks for getting in touch and I'm sorry that you're having problems with your connection.
Testing your line isn't showing any issues, and it's actually connected right at the top end of the estimates:
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0003 | ||||
Description | No problem found, OAM test is not currently supported on this line. | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 77.4 Mbps | ||||
Upstream Speed | 16.5 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream 4dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2017-05-27T13:30:00 |
Featured Products |
Downstream Line Rate(Mbps) |
Upstream Line Rate(Mbps) |
Downstream Handback Threshold(Mbps) |
WBC FTTC Availability Date |
WBC SOGEA Availability Date |
WBC FTTC 18x2 Provide Availability |
WBC FTTC 18x2 Sim Availability |
Left in Jumper |
High | Low | High | Low | |||||||
VDSL Range A (Clean) | 77.6 | 57.8 | 20 | 20 | 51.2 | Available | -- | -- | Yes | -- |
Can you run a BT Speedtest for me on a wired connection, ensuring you do the further diagnostics test after the first one completes. This stores the results on the supplier system and allows us to use this to report the fault.
09-06-2017 6:15 PM
Is this not a issue ?
09-06-2017 6:22 PM
I'd have expected the bridge tap to have reduced the sync speeds, or caused connection issues if it was a problem. As it hasn't and the problem seems to be the throughput we'd need a BT speedtest completing to see what that shows on a wired connection.
