fiber went live 2day
staceyd86
hi i have just moved from bt to plusnet, when i was with bt i was synced at 80.00mbps but only synced at 73.55mbps now with plusnet. will this go up ?
Fixes: 233
Re: fiber went live 2day
Hi there and welcome aboard.
Line tests are showing a potential fault, so we'll get that raised to Openreach now for you. We'll provide updates to your via this ticket on your account when we have more info.
Anoush
Fixes: 8
Hi @Gandalf   I've spotted this issue of 'potential line fault' being reported in several recent posts where Users are changing ISP.  Is this an Openreach problem that needs feeding back?
Fixes: 233
If I remember correctly it was a battery contact fault we detected on the line and the migration was a straight transfer from BT retail so it appears that it’s just a really big coincidence. :/
staceyd86
thanks for the help guys look forward to tho outcome
Fixes: 233
No problems, let us know how it goes over the next few days.
staceyd86
reset router 2day and stats are..........
1. Product name: Plusnet Hub
2. Serial number: +081441+NQ71601297
3. Firmware version: Software version 4.7.5.1.83.8.237.2.2 Last updated 08/09/17
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 00:04:20
6. Data rate: 20000 / 77128
7. Maximum data rate: 24386 / 77201
8. Noise margin: 6.9 / 6.0
9. Line attenuation: 12.0 / 12.4
10. Signal attenuation: 11.9 / 12.4
i have a bt smarthub 6 but i dont like the wifi on it, would it be a better router to use ?
