fiber went live 2day
staceyd86
hi i have just moved from bt to plusnet, when i was with bt i was synced at 80.00mbps but only synced at 73.55mbps now with plusnet. will this go up ?
6 REPLIES 6
Fixes: 1,600
Re: fiber went live 2day
Hi there and welcome aboard.
Line tests are showing a potential fault, so we'll get that raised to Openreach now for you. We'll provide updates to your via this ticket on your account when we have more info.
Anoush
MauriceC
Resting Legend
Fixes: 17
Hi @Gandalf   I've spotted this issue of 'potential line fault' being reported in several recent posts where Users are changing ISP.  Is this an Openreach problem that needs feeding back?
Fixes: 1,600
If I remember correctly it was a battery contact fault we detected on the line and the migration was a straight transfer from BT retail so it appears that it’s just a really big coincidence. 😕
staceyd86
thanks for the help guys look forward to tho outcome
Fixes: 1,600
No problems, let us know how it goes over the next few days.
staceyd86
reset router 2day and stats are..........
1. Product name: Plusnet Hub
2. Serial number: +081441+NQ71601297
3. Firmware version: Software version 4.7.5.1.83.8.237.2.2 Last updated 08/09/17
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 00:04:20
6. Data rate: 20000 / 77128
7. Maximum data rate: 24386 / 77201
8. Noise margin: 6.9 / 6.0
9. Line attenuation: 12.0 / 12.4
10. Signal attenuation: 11.9 / 12.4
i have a bt smarthub 6 but i dont like the wifi on it, would it be a better router to use ?
