fiber speeds
baccini
fiber speeds
Hi originaly had 76mb line and achieved 54mb
now i have        66mb line and achieved 44mb why not 54mb?
16 REPLIES 16
Strat
Fixes: 565
Re: fiber speeds
Moderator's note by Dick (Strat): Post removed as bumping is against the Forum Rules.
Fixes: 1,600
Re: fiber speeds
Thanks for your post @baccini and apologies for the delayed response. I've tested your line tonight and I can see your router is getting a speed of 51.7mbps which is below the current expectations of your line at between 52.8mbps to 75.3mbps.
Could you run through our troubleshooting guides Here making sure your router is plugged into the test socket as explained Here. If you're still experiencing problems, please report a fault to us Here posting back afterwards. This will allow us to get the fault picked up for you as soon as possible.
baccini
Re: fiber speeds
Thanks for the response I currently have my own asus router in use,do I need to set up a plusnet router before I report a fault.
Fixes: 1,600
Re: fiber speeds
Thanks for getting back to me @baccini
You don't need to use our router although it's probably a good idea to try another router so it may be worth plugging your Hub One into the test socket and let us know so we can retest your line. That way you'd kill two birds with one stone (Metaphorically of course, no birds will be harmed I hope) ruling out your internal wiring and your router.
baccini
Re: fiber speeds
ran b.t speed tests on both routers with almost identical results asus 42.77Mbps & hub one 42.54.test done from the main socket open reach MK2 which is the only socket we have.laptop wired directly on both tests.
Fixes: 1,600
Re: fiber speeds
You won't see an immediate increase in your throughput as the profile on your account wouldn't change that quickly. Can you confirm that your router is still in the test socket so I can retest your line?
baccini
Re: fiber speeds
Hi bt Mk 2 socket has no master socket i can cofirm its the only phone socket in the house and modem is directly plug in to it.
Fixes: 1,600
Re: fiber speeds
An Openreach MK2 should be a master socket and have a faceplate you can remove by unscrewing it. Behind the faceplate towards the bottom right hand corner you'll find the test socket.
If you don't see this can you post up a photo of the socket so I can advise further?
baccini
Re: fiber speeds
baccini
Re: fiber speeds
First photo show my normal connection second is using a black adapter give me no connection ie. no green light on the dsl (BT modem)
Fixes: 1,600
Re: fiber speeds
Thanks for the photos, the adapter you're using doesn't look like a micro-filter.
Was that what we supplied you with the Hub One?
baccini
Re: fiber speeds
never used filters since i had the new bt socket fitted.do you think i should be using filters?
baccini
Re: fiber speeds
Ok ive set it up with a filter to the engineers connection
Fixes: 1,600
Re: fiber speeds
Cheers, it's perfectly fine to use a micro-filter still and using the test socket would rule out any internal wiring including the faceplate from being faulty or confirming that to be the cause for the fault.
(I leave my own router at home permanently in the test socket)
Line tests are showing your sync speed has increased marginally though to 55.1mbps which is within expectations for the length and quality of your line back to the cabinet (The green box in the road)
I've increased a profile on your account to match this new sync rate, if you can drop the PPP session by doing a disconnect then reconnect in your router's settings, you should see a higher download speed afterwards.
To address the points you've made in your initial post, you're still on the 80/20 product. I think the confusion lies with the average speed of 66mbps we advertise Fibre Extra as. This is just an average speed across our fibre extra customer base and is just how we have to advertise packages, we can't say "up to 76mbps" anymore due to regulations.
What's more important are the actual expectations of your line shown on the BT Broadband Availability Checker Here.
If you'd want to use your own router going forward, I'd recommend next plugging that into the test socket before replacing the faceplate to try to figure out where the drop in speed is coming from.
