ffffeeeeedddddddd upppp slllllloooooowwww aaaattt ppppeaaaakkk tttimmess
- ffffeeeeedddddddd upppp slllllloooooowwww aaaattt ...
Re: ffffeeeeedddddddd upppp slllllloooooowwww aaaattt ppppeaaaakkk tttimmess
07-08-2016 12:14 PM
IP starting 51, cant gateway hop to get off it !
Connected gateway. core2-hu0-18-0-0.southbank.ukcore.bt.net
07-08-2016 12:22 PM
I can't see subnet that i am on but
IPv4 Address: | 209.93.**.** | ||
Primary DNS: | 212.159.6.9 | ||
Secondary DNS: | 212.159.6.10 |
do plusnet do static ip addresses?
07-08-2016 12:36 PM
I'm on gateway pcl-bng01 at the moment, not sure if it might be related to gateway issues or ip issues.
Yes Plusnet do static IPs, you can get one by signing into the Member Centre and going to Add-ons. It's a £5 one off charge.
07-08-2016 1:43 PM - edited 07-08-2016 1:45 PM
I have the HG612 3B BT modem (hacked, so that I can see the stats) with a 4th gen Apple Airport Extreme router. Also IP starts 51.9.
07-08-2016 1:54 PM
Have any of you tried changing gateway?
I have a static IP address and was showing packet loss from gateway pcl-ag07, changing to gateway ptn-bng01 removed the packet loss.
07-08-2016 4:28 PM - edited 07-08-2016 4:29 PM
Gateway hopping does not seem to be an option for those of us on the new network. The IP and gateway are very sticky.
on 07-08-2016 5:12 PM - last edited on 07-08-2016 5:38 PM by Mav
This is the problem, hence I'm moving to BT tomorrow, being stuck on a poor connection/gateway with no option of getting off it.
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules
07-08-2016 7:46 PM
I am looking forward to athruntalan bt engineer outcome tomorrow. Can you keep us informed?
Must admit i am considering moving away from Plusnet because of this issue. I have switched off everything other than the router and modem today, wifi was turned off with no devices connected between 3.00pm - 4.30pm and the packet loss started to increase
If it is REIN interference then its not this end of the line. During that time no electrical device was on.
07-08-2016 7:47 PM
07-08-2016 8:26 PM
shame you have to pay additional £5 a month for a stable connection. When it should be as standard.
07-08-2016 8:30 PM
However, the static ip I had a couple of weeks ago degraded as well after having it for about a week, so I'm not entirely convinced it won't happen again.
07-08-2016 8:33 PM - edited 07-08-2016 8:35 PM
A static IP is a one-off charge of £5, not a monthly charge.
edit: posted at same time as @athruntalan
08-08-2016 9:25 AM
I'll let you know how I get on.
08-08-2016 10:26 AM
Thank you for getting back to us. Kind of confirms its more of capacity issue rather than local or network hardware issues.
If your static IP is not showing issues have you had a monitor on the line?
08-08-2016 11:14 AM
Yes, I've been monitoring my traffic since early last week, and the static ip has shown none of the packet loss in the monitor that either of the other IP networks have.
