extension for new install?
- Re: extension for new install?
11-06-2015 6:49 PM
Hi the engineer came today and said my old internet cable was not good enough to extend the modem from the kitchen telephone line into my living room (about 10-15 metres). He said BT would cost £150 so I let him put them in the kitchen and am now relying on WiFi.
I got the more expensive 76mb fibre to get a better service. I don't think I am happy with my modem and router in the kitchen, which also means I have lost BBCi etc from my TV .
There must be a cheaper way to extend either the modem or the router 15 metres?
Wasn't expecting ths when I switched from BT
Message 1 of 6
(996 Views)
5 REPLIES 5
11-06-2015 6:52 PM
I have my modem right next to the phone socket, as recommended, but the router (Asus) on the end of a 10 metre cat6. Works perfectly.
Let's be careful out there !
Message 2 of 6
(691 Views)
11-06-2015 7:10 PM
Quote from: Kremmen I have my modem right next to the phone socket, as recommended, but the router (Asus) on the end of a 10 metre cat6. Works perfectly.
Thanks, is a cat6 an ethernet cable?
Message 3 of 6
(691 Views)
11-06-2015 8:19 PM
The modem ideally needs to be next to and connected to the master phone socket using as short as possible modem cable, the router can be anywhere up to 100 meters if using a cat 5/6/7 cable and yes they are Ethernet.
I'm not sure what cable you were using that the engineer said wasn't any good if it were a modem cable then yeah 10 -15m is pushing it especially if it's the standard flat type, I'm not sure why your master socket is in the Kitchen to begin with seems a strange place for it to be, but if that is where it is then leaving the modem there would be ideal then if you want to be wired rather than wireless put the modem in the living room and run a cat cable from that to the modem.
Message 4 of 6
(691 Views)
11-06-2015 9:21 PM
Quote from: Terranova667
Hi, thanks. Yeah the cable was a telephone extension and went through the wall, so was something around 4-6 meters. But I am going to go with yours and Kremmens advice.
Just checked and I can run a cable through the hole in the wall that is already there, and saw a kit on Ebay for a cutter, crimping tool and 10 RJ45 connectors for under a fiver and a ready made 5e cable for a couple of quid. So I can feed the cable through the wall and then just crimp a connector on the other end. So 4-6 meters and job done
Message 5 of 6
(691 Views)
13-06-2015 6:55 PM
high yeah that would do well just make sure you get the order of the wires in the connectors correct to make a straight through Ethernet cable not a crossover, here is a nice guide to help you out if you don't know already how to make one. http://www.groundcontrol.com/galileo/ch5-ethernet.htm
Message 6 of 6
(691 Views)
