erratic and slow broadband speed
- erratic and slow broadband speed
22-11-2019 10:09 PM
Hi Can someone test connection etc have attached results of btwholesale test and this can get even slower on some days.
Have done the resetting of router / clear cache / check for filter etc etc but still slow.
Thanks in advance
Re: erratic and slow broadband speed
22-11-2019 10:19 PM
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
23-11-2019 2:20 PM - edited 23-11-2019 2:21 PM
Hi @nidge,
Checking from this side everything is looking spot on to the router with 79.9Mbps download and 20Mbps upload.
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 79.9 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 258.1 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Current 15Min Bin Retrains | 0 |
Last 15Min Bin Retrains | 0 |
DP Type | External |
Profile Name | 0.128M-74M Downstream, Retransmission High - 0.128M-20M Upstream, Retransmission High |
Time Stamp | 2019-11-10T14:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 57.1 Mbps | 79.9 Mbps | 73.3 Mbps |
Up Stream Line Rate | 20.0 Mbps | 20.0 Mbps | 20.0 Mbps |
Up Time | 530.0 Sec | 900.0 Sec | 899.1 Sec |
Retrains | 0.0 | 2.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-11-23T13:43:54Z | 2019-11-23T13:58:54Z |
Ingress Code Violation | 0 | 7 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Were your speed tests performed using a wired or wireless connection?
