emerging router issue?
- Re: emerging router issue?
07-06-2015 7:27 PM
08-06-2015 2:57 AM
There are a few threads on this, ADSL & Hardware boards where people are having a variety of issues, this could be yet another.
If you login to it using http://192.168.1.254/expert_user.html does the >Device Info >DHCP page give the hostname for the problematic devices as "Unknown"? Are the devices listed there the same as the Homepage under My Home Network?
(see screen grabs for guidance).
08-06-2015 10:28 AM
This looks the same as the problem that I've been experiencing. Devices say they are still connected to the network, but there is no internet access. I assumed for that reason, that the Openreach modem was at fault, and would still assume that was the case. We have no access to the modem, only the router. Internet has dropped out on me three times this morning, so I also wasn't sure, if there was an issue with the, so I will be reporting it.
08-06-2015 1:41 PM
I had assumed that he was using the 2704n, but looking back through a few of his recent posts, he maybe using the TG582n.
penfold, if that's the non-USB version that you've flashed with the FTTC firmware, there is a possibility that might be causing the problem. If you can borrow another Router to try and see if that resolves it.
IIRC, your set-up is quite complex, so I wouldn't bother with the 2704n because of it's current lack of features - unless you have successfully set it up in your network - which I'm thinking is unlikely
08-06-2015 3:16 PM
I am currently using the Sagem offering, as I had to simplify the network, due to redecoration, and still not got around to putting everything back together
I havnt flashed the 585 unit I have at the min, as the Sagem worked out of the box, for what I needed it for currently.
I will have a look at the Expert user webpages tonight, and post back what it says. With regards to the problematic devices, all wirless devices refused to connect, but saw the network fine. When I tried to connect them, the device tried to connect, but failed. Sorry for not trying the wired device, my wife needed to access internet, so as always, that was the priority
Currently on the network is 1 laptop, 1 tablet, and a Sky box wired. Everything else is currently disconnected.
I think its time to reflash the 585 unit methinks. Plusnet are going to have to look at the Sagem unit, as its causing more problems than its fixing. Very un-savvy customers, could potentially flood the call centre, if this becomes more widespread.....
08-06-2015 3:25 PM
08-06-2015 8:24 PM
08-06-2015 8:53 PM
09-06-2015 8:42 PM
going to flash the 585n I have with fttc firmware. If you know, do I need the 10.2.5.2 eo or fo. Also my 585n has no usb port, does this matter.
thanks for the help.
09-06-2015 11:02 PM
I haven't tried the F0, but there's only minor changes from E0 mainly to do with multimedia and the few comments I've seen imply it's OK. As for it being on a non-USB model, it will go on and will work, but, I was reading a recent post where someone has done this and it had been working but subsequently got locked up at some point and a reboot was needed, whether that's because of the missing bits of hardware in the non-usb version, I wouldn't like to say. Give it a go if it is the 582n.
